Preparing an inReach Mini Series for a Transfer of Ownership or Return
When transferring ownership of an inReach® satellite communicator, the new owner will need to create their own inReach account. Prior to selling, returning, or giving your device to a new owner follow the steps below to cancel your inReach service or transfer it to another device, then perform a factory reset on the inReach device you are selling, returning, or giving away. Performing these steps ensures that the new owner of the inReach unit will be able to activate the device to their own account and will not have access to any of the message history or contacts on the unit.
Transferring inReach Service
If you already have another inReach satellite communicator in your possession, you can transfer the existing service to it instead of canceling. For steps, see - Transferring Existing inReach Service to Another inReach Device.
Canceling Service for an inReach Satellite Communicator
NOTE: Canceling service may incur fees for early termination, and additional fees if you choose to activate again later. If you are preparing a device for a transfer of ownership, but plan on activating a different device later, contact Garmin Services Billing to discuss your options. The process for canceling your service is the same whether the inReach device is suspended or active. Suspending a device does not allow for it to be transferred to another account.
Cancelling inReach Service Using the Garmin Website
  1. Log in to the Subscription Portal.
  2. Select MANAGE on the subscription you want to cancel.
    Manage Button
  3. Select CANCEL PLAN.
    Cancel Button
  4. If you are currently on an Essential, Standard, or Premium plan you will be prompted with an option to switch to an Enabled plan.
    If you still wish to cancel, select CONTINUE WITH CANCEL.
    NOTE: If you are currently on a Freedom or Annual plan and wish to switch to an Enabled plan, select BACK and choose the option to CHANGE PLAN or REACTIVATE PLAN instead.
  5. Select CANCEL IMMEDIATELY when prompted to finalize cancelling service.
Cancelling inReach Service Using the Earthmate® App (inReach Mini Only)
  1. Open the Earthmate app.
  2. Select Three horizontal lines (Android™) or More (iPhone®/iPad®).
  3. Select My inReach.
  4. Select Manage Subscription.
    My inReach Page With Manage Subscription Option
  5. Select Cancel Plan.
    Earthmate Manage Subscription Page
  6. If you are currently on an Essential, Standard, or Premium plan you will be prompted with an option to switch to an Enabled plan.
    NOTE: If you are currently on a Freedom or Annual plan and wish to switch to an Enabled plan, select BACK and choose the option to Change Plan instead.
    Earthmate Cancel Plan
  7. Select CANCEL IMMEDIATELY when prompted to finalize cancelling service.
    Earthmate Cancel Immediately
Cancelling inReach Service Using the Garmin Messenger™ App (inReach Mini 2 Only)
  1. Open the Garmin Messenger app.
  2. Select Device.
  3. Select your current plan type below the picture of your inReach device.
    inReach Mini 2 Connected With Premium Plan
  4. Select Cancel Plan.
    Plan Options in Garmin Messenger
  5. If you are currently on an Essential, Standard, or Premium plan you will be prompted with an option to switch to an Enabled plan.
    Garmin Messenger Cancel Service
  6. Select CANCEL IMMEDIATELY when prompted to finalize cancelling service.
    Garmin Messenger Cancel Immediately
Sending a Cancellation Request to Garmin Services Billing
Send your request to GarminServicesBilling@garmin.com. The request must state that you wish to cancel service, and also include the following:
  • Email address the service is under.
  • Billing address of the credit card used on the account.
  • IMEI number of the device.
Failure to submit the proper information can delay implementation of your cancellation.
Requests of cancellation will be processed and become effective within 2 business days of submission. Garmin is closed on weekends and holidays.
Performing a Factory Reset on the inReach Device
inReach Mini
  1. From the home page, press OK to open the main menu.
  2. Select Setup.
  3. Select Recovery Options.
  4. Select Restore Defaults.
  5. The inReach will reset and reboot to the activation page. Hold down the Power button to power down the device.
inReach Mini 2
  2. Select Settings.
  3. Select System.
  4. Select Reset Device.
  5. Select Delete Data and Reset Settings.
  6. The inReach will reset and reboot to the activation page. Hold down the Power button to power down the device.
Additional Steps For the Garmin Messenger App
If you have used the Garmin Messenger app with your inReach Mini 2 and wish to go back to receiving inReach messages in your phone's default text messaging app, you will need to remove your phone number in the Garmin Messenger app using the steps below:
    • NOTE: If you already uninstalled the Garmin Messenger app, reinstall it and follow the prompts to verify your phone number again.
  2. Select the profile icon or Gear Symbol in the top left.
  3. Select Accounts.
  4. Select Manage Garmin Messenger Account.
  5. Select Delete Garmin Messenger Account.
  6. Select Delete Account.
Once these steps have been completed, the Garmin Messenger app can be uninstalled and future inReach messages sent to your phone number will be received in your phone's default text messaging app.
