Using the Sunrise and Sunset Glance on an Outdoor Watch
Most Garmin watches offer a sunrise and sunset widget or glance, which provides time information about dawn, sunrise, sunset, and dusk. Some Garmin watches also include enhanced sunrise and sunset information in the glance. This information includes a map showing the relative position of the sun to you, a graphical representation of how high in the sky the sun will rise, and further details about astronomical and nautical dawn and dusk. Within the glance, you can also view information for different dates, locations, and times of the day. Viewing the map within the glance will turn on GPS as the watch reaches out to find your position, and it may take a moment for it to locate you, depending on signal strength. Having a clear view of the sky can help with acquiring GPS quicker.
Viewing an Alternate Date
To view sunrise and sunset information for different days within the widget, follow the steps below.
Press Down (bottom left button) to locate the Sunrise/Sunset glance.
Press Start (top right button) to open the glance.
Press Start (top right button).
Select Change Date.
Press Up (middle left button) or Down (bottom left button) to adjust the date.
You can then scroll through the glance screens to view additional information for that day.
Viewing an Alternate Location
The glance can also show you information for alternate locations.
Select Change Location.
Select an option.
Current Location uses your current GPS location.
Coordinates allows you to enter a location's coordinates.
Use Map allows you to select a location from the map.
Saved Locations allows you to select a previously saved location.
City Search allows you to search for a city. Type in the city from the watch itself or use the Instant Keyboard in the Garmin Connect App.
Once you have selected a location, you can scroll through the widget to view additional information for that location.
Viewing an Adjusted Time
To view sun position or height at a different time from the current time, follow these steps.
Press Down (bottom left button) to go to the map or graph screen within the glance.
Select Change Time.
Press Up (middle left button) or Down (bottom left button) to adjust the time.
Sun position is not available before dawn or after dusk.
