I've Lost My Garmin Device
Garmin does not have a way to remotely track your device, disable updates, or access to delete contents on the device. If you have lost your watch, there are a couple of things that you can try to locate your device.
If your inquiry is for an inReach handheld device, see Related.
Check Garmin Connect
Devices that have been paired to a smartphone through the Garmin Connect app will display information on when it last synced. If it has synced with your account recently, that means it was within Bluetooth range of your smartphone.
The Daily Summary section will display the date and time the device last synced with Garmin Connect:
Use the Garmin Connect App to Help Find Your Device
If you have previously connected your device to your smartphone or tablet through the Garmin Connect app and the Garmin device is within Bluetooth range of your mobile device, the Find My Device (also known as Find My Watch) feature may be able to locate it.
Watches Compatible With Find My Device
Refer to your owner's manual for additional information.
Approach S40
Approach S42
Approach S62
D2 Air Series
D2 Mach 1
Descent G1 Series
Descent Mk1
Descent Mk2 Series
Enduro
epix (Gen 2) Series
fenix Chronos
fenix 3
fenix 3 HR
fenix 5 Series
fenix 5 Plus Series
fenix 6 Series
fenix 7 Series
Forerunner 45 Series
Forerunner 55
Forerunner 245 Series
Forerunner 255 Series
Forerunner 645
Forerunner 745
Forerunner 935
Forerunner 945/945 LTE
Forerunner 955/955 Solar
Instinct Series
Lily
MARQ Collection
quatix 5
quatix 6
tactix 7 Series
tactix Bravo
tactix Charlie
tactix Delta Series
Venu Series
Venu 2 Series
vivoactive 3
vivoactive 3 Music Series
vivoactive 4 Series
vivomove HR
vivomove 3 Series (Including: Sport, Style, and Luxe)
vivosmart 3
vivosmart 4
vivosmart 5
Using Find My Device in the Garmin Connect App
Open the Garmin Connect app.
Open the Menu:
Android: Select (top left).
iOS: Select More (bottom right).
Select Garmin Devices.
Select the name of your device.
If the device is Connected, scroll to the bottom of the screen and select Find My Device.
The watch will emit an audible beep and/or vibration.
