Installation of a VDO Rudder Feedback Sensor to Compatible GHP Autopilots
To connect a VDO Rudder Feedback Sensor to a GHP 12 or GHP Reactor Mechanical/Retrofit/Solenoid autopilot, an external resistor of equal resistance to the feedback sensor must be added.
The resistor should be 180 ohms with at least 1/10th watt or larger. Most leaded resistors are 1/4 Watt, which will work as well.
NOTE: VDO is a brand of instrument. They make traditional gauges as well as OEM dashboards. Follow this link to see their Rudder Feedback Sensor: VDO Rudder Feedback Sensor
