USB Flash Drive not Detected by a Honda Vehicle
Communication issues can prevent your USB flash drive from being recognized by your vehicle.
- Ensure the flash drive is 16GB and has been formatted to FAT32.
- The Honda Navigation System update requires a 16GB USB flash drive. Using a USB flash drive smaller or larger than 16GB can cause the map update process to be unsuccessful.
- Ensure the proper USB port in the vehicle is being used.
- Try a different USB port if the vehicle has the ability to use more than one.
- See Honda Navigation Map Update for info on which USB ports can be used in your vehicle.
- Try a different formatted 16GB flash drive.
- We suggest using a different brand or variation of 16GB flash drive.
- Garmin has not tested any specific USB flash drive for map update use.
Contact Garmin Product Support for assistance if these steps do not resolve the issue.
