How to Set Up DSP Using FusionLink
The Fusion-Link app can be used to set up DSP (Digital Signal Processing) for compatible stereos and amplifiers.
Compatible DSP Stereos
Fusion Apollo MS-WB670 Hideaway Stereo
Setting up DSP for the Internal Amplifier:
- Connect the mobile device with the Fusion-Link application to the stereo using Wi-Fi or Bluetooth
- Open the Fusion-Link app and select the connected stereo if necessary
- Tap the Settings Menu gear in the upper right corner of the screen
- In the Music tab select the Zone the amplifier is connected to
- Select DSP Settings
- The app will notify that the DSP Setting Download is done, tap Close
- Select Internal Amplifier
- Tap Speaker Type and specify the installed speakers
- Tap Environment and choose the closest option to the area in which the speakers are installed
- If a second pair of speakers or a separate Tweeter is connected toggle the options on by tapping the switch
- Return to the Zone menu and select Send DSP Settings
- Fusion-Link will notify Update Complete, tap Close
Setting up DSP for External Amplifiers
- Select External Amplifier
- Select External Amplifier to specify the amplifier
- If using a Signature, FM or AM Series amplifier, Fusion-Link will then provide the trimpot settings. These MUST be applied to the amplifier before sending DSP settings
- If using an Apollo Series amplifier return to the Settings screen and tap Send DSP Settings
