User Data Limitations of the eTrex Touch 25, 35, and 35t
When sending or creating files for an eTrex® Touch 25, 35, or 35t device, keep in mind the following limitations:
  • 2,000 GPX files
  • 4,000 waypoints
  • No limit on geocaches (outside of max number of GPX  files supported and memory available)
  • 200 routes, 250 points per route; 50 points turn-by-turn routing
  • 200 saved tracks
  • 2,000 archive tracks
  • 10,000 points per track
  • 100 custom map tiles
  • 250 BirdsEye Imagery files
  • Mapping segments1 vary by model:
    • eTrex Touch 25 and 35: approximately 4,000
    • eTrex Touch 35t: approximately 3,500 (due to internal mapping)
Each GPX file can contain a mixture of waypoints, geocaches, routes, and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device.
When utilizing routes, only 50 points can be used for turn-by-turn navigation on roads or trails.
1 See Related for more information on map segments.
Related
