Cortex® Release History
Updating your Cortex
Your Cortex devices are updated through the Cortex Onboard App. The Cortex software is downloaded with a Cortex Onboard install or update. You can do this at any time you have data coverage or WiFi availability, just like any other App update. Cortex Onboard will then distribute that update to your Cortex system next time you connect, it's that easy.
List of Cortex® Software Releases
The following is a version release history for Cortex Software:
2.1.36 - 8/29/2024
Release Date
August 29th, 2024
Release Versions
Cortex v2.1.36 contains:
Handset: 2.1.28
Hub: 2.1.2890
It is included in the Cortex Onboard app versions:
Cortex Onboard iOS: 1.15.3 (4)
Cortex Onboard Android: 2.1.29 (399)
Release Notes
Improvements and bug fixes:
  • iOS: Allow Cortex updates to upload while the Cortex Onboard app is in the background.
  • Cortex: Improved stability for long-running system that are using Cortex Monitor.
  • Cortex: Fix issue where GPS satellite data is not displayed correctly on Garmin GPSMAPs device and non-Garmin MFDs.
  • Handset (H1 and H1P): No updates.
2.1.34 - 5/28/2024
Release Date
May 28th, 2024
Release Versions
Cortex v2.1.34 contains:
Handset: 2.1.28
Hub: 2.1.2884
Cortex Onboard iOS: 1.15.2 (0)
Cortex Onboard Android: 2.1.28 (397)
Release Notes
  • Improve VHF audio performance for long duration VHF transmissions.
2.1.32 - 12/13/2023
Release Date
December 13, 2023
Release Versions
Cortex v2.1.32 contains:
Handset: 2.1.18
Hub: 2.1.1935
Cortex Onboard iOS: 1.15.1 (4)
Cortex Onboard Android: 2.1.27 (396)
Release Notes
  • Fix incorrect magnetic variation values in some NMEA 2000 PGNs for some locations in the world
  • Fix issue that causes Cortex Monitor app issue to not start properl and vessel information not being updated
  • Remove channel 2006 (6B) from all international (INT) VHF catalogues
2.1.25 - 10/26/2023
Release Date
October 26, 2023
Release Versions
Cortex v2.1.25 contains:
Handset: 2.1.18
Hub: 2.1.2879
Cortex Onboard iOS: 1.14.0 (15)
Cortex Onboard Android: 2.1.18 (388)
Release Notes
New Features:
      • There is now a swipe-down menu on the handset for quick-access settings.
      • Monitor only mode – disable AIS, VHF, and all alarms while you are away from the boat but keep remote monitoring running.
      • MOBs and waypoints can now be cleared.
      • View VHF duplex channels in the old A/B format, or as 10/20 format.
Enhancements:
      • Scan All mode now allows for skip broadcast channels.
      • Cloud: The “Prefer boat network” option now detects when the boat network is not connected to the Internet and falls back to the Cortex cellular modem.
      • The iOS settings menu structure now follows Android and the handset.
      • Numerous small bug fixes and stability improvements.
Software Release Document
2.0.20 - 6/8/2023
Release Date
June 8, 2023
Release Versions
Cortex v2.0.20 contains:
Handset: 2.0.18
Hub: 2.0.2802
Cortex Onboard iOS: 1.14.3 (1)
Cortex Onboard Android: 2.0.18 (361)
Release Notes
  • Fixed rare occurrence where WiFi is lost and system is not responding.
  • Enhance VHF reception on weak incoming signals and avoid audio clipping.
2.0.13 - 4/6/2023
Release Date
April 6, 2023
Release Versions
Cortex v2.013 contains:
Handset: 2.0.13
Hub: 2.0.2799
Cortex Onboard iOS: 1.14.1 (0) upward
Cortex Onboard Android: 2.0.13 (360) upward
Release Notes
  • Fix issue with weather channels not being audible in USA.
2.0.12 - 3/31/2023
Release Date
March 31, 2023
Release Versions
Cortex v2.012 contains:
Handset: 2.0.11
Hub: 2.0.2797
Cortex Onboard iOS: 1.14.0 (15) upward
Cortex Onboard Android: 2.0.11 (359) upward
Release Notes
Improvements:
  • SquelchEQ automated squelch with manual fine-tuning
  • Omni watch multichannel scanning
  • VHF audio recording and playback
  • Added VHF weather channel preset
  • AIS collision avoidance shortcut added to the plotter
  • Visual and layout improvements for Cortex™ handsets
  • Visual and layout improvements to Cortex Onboard™ app on Android devices
  • Improved landscape scalability for Cortex Onboard™ app on iOS for iPad® devices
  • Enable conversion between NMEA 2000® networking and NMEA 0183 for the following 0183 sentences: BOD, XTE, RMB, APB, HDT, HDM, BWW
1.8.30 - 09/07/2022
Release Date
September 07, 2022
Release Versions
Cortex v1.8.30 contains:
Handset: 1.8.27
Hub: 1.8.2551
Cortex Onboard iOS: 1.12.2(2) upward
Cortex Onboard Android: 1.8.27 (344) upward
Release Notes
  • Fix: handset crash when the instruments page was displayed for a very long time with the internal heading sensor enabled
  • Fix: the Magnetic Variation PGN sent over the NMEA 2000 network would in some cases contain incorrect Magnetic Variation values
  • Fix: Occasionally when Cortex™ would start the NMEA 2000 network was not detected
1.8.26 - 07/22/2022
Release Date
July 22, 2022
Release Versions
Cortex v1.8.26 contains:
Handset: 1.8.26
Hub: 1.8.2546
Cortex Onboard iOS: 1.12.0 (13) upward
Cortex Onboard Android: 1.8.26 (340) upward
Release Notes
New Features:
  • Improved squelch control and responsiveness - tunable from the click wheel
  • Handset will play an audible alarm on a lost Wi-Fi connection
  • Play announcement over the external speaker when an external alarm silence switch is activated
  • NMEA data source management available from iOS Cortex Onboard app
  • Production service release
  • Dual Watch no longer automatically disables on a channel change
  • ATIS mode will no longer receive rouge DSC messages
  • Improved Hub Wi-Fi stability when no client devices are connected
  • Cloud connectivity improvements
  • Fix Hub external speaker sometimes clipping the end of a VHF call
  • Fix spurious AIS SOG data
  • Improved NMEA 0183 and NMEA 2000 invalid character handling
1.7.35 - 02/10/2022
Release Date
February 10, 2022
Release Versions
Cortex v1.7.35 contains:
Handset: 1.7.25
Hub: 1.7.2445
Cortex Onboard iOS: 1.11.2 (4) upward
Cortex Onboard Android: 1.7.27 (308) upward
Release Notes
This release improves stability of the Cortex system when operating on a NMEA 2000 network. Its is strongly recommended to update to 1.7.35 from 1.7.27 or 1.7.32.
1.7.32 - 01/21/2022
Release Date
January 21, 2022
Release Versions
Cortex v1.7.32 contains:
Handset: 1.7.25
Hub: 1.7.2444
Cortex Onboard iOS: 1.11.1 (1) upward
Cortex Onboard Android: 1.7.25 (305) upward
Release Notes
This release improves stability of the system when left running for long periods of time. Its is strongly recommended to update to 1.7.32 from 1.7.27.
Other changes of note:
  • Fixed bug where Mexico was not always being included on Cortex M1-USA monitoring roaming coverage
  • Added Hong Kong VHF region with local channels
1.7.27 - 12/20/2021
Release Date
December 20, 2021
Release Versions
Cortex v1.7.27 contains:
Handset: 1.7.23
Hub: 1.7.2439
Cortex Onboard iOS: 1.11.0 (26) upward
Cortex Onboard Android: 1.7.24 (303) upward
Release Notes
New Features:
  • Loud hailer
  • Fog and Horn Signaling
A quick guide on wiring up a loudspeaker can be found here:
  • NMEA Data Sources
  • NMEA 2000 internal sensor output
  • Internal sensor offset adjustments
  • Internal sensors on instruments views
  • VHF channel lock
  • Faster VHF channel change
  • VHF Mute control now includes DSC calls
  • Fixed button backlight brightness levels in night mode
  • Increase zoom level on handset plotter view
  • Fixed back button on idle wake actioning the back button
  • Improvements to the volume control
  • GPS Galileo configuration improvements
  • Added more cloud connectivity diagnostics
  • Included Mexico in Cortex M1 Hub-USA monitoring roaming coverage
  • Handset button handling improvements (wake from sleep on back button fix)
  • VHF TX audio quality improvements
  • Handset connectivity improvements
  • Cortex Onboard™ app user interface improvements and bug fixes
  • Improved cloud connectivity, including more supported countries
  • Improved remote diagnostics
  • No longer auto disabling GPS smoothing when dropping anchor
  • Fixed OTA update not working over Boat Network
  • Being more proactive with DHCP client (Boat Network) behavior
  • Fixed not being able to send .vsm if opened the landing page through a Boat Network
  • Adding chirps when the hub external speaker volume changes due to user interaction
  • Fixed issue that caused certain characters on Wi-Fi password to make it not work
  • Fixed issue that would cause multiple Wi-Fi restarts if clients became unreachable
  • Fixed issue with cellular modem crashing
  • Fixed issue where cloud would not reconnect
  • Added cellular region, so the user can see it
  • Added more countries for cellular service
  • Fixed issue where cellular modem gets “stuck” on a particular cellular operator
  • Changed the cloud over boat-network behavior to prefer the boat network
  • Added ability to toggle pressure and heading output over NMEA 2000
  • Fixed issue where heading is not always emitted over AIS
  • Fixed issue where NMEA 2000 depth and water speed values are dropped
  • Other minor bug fixes and user interface improvements on the Cortex® Handset and Cortex™ Hub
1.6.14 - 06/22/2021
Release Date
June 22, 2021
Release Versions
Cortex v1.6.14 contains:
Handset: 1.6.5
Hub: 1.6.2229
Cortex Onboard iOS: 1.10.0 (0) upward
Cortex Onboard Android: 1.6.5 (281) upward
Release Notes
  • Remote programming of Cortex AIS details and ATIS ID
  • Stealth mode input switch
  • Added NMEA 0183 Daisy Chaining.
  • Updated Cortex Hub web page interface on 10.1.1.1
  • Handset UI improvements
  • Minor bug fixes
1.5.36 - 05/03/2021
Release Date
May 03, 2021
Release Versions
Cortex v1.5.36 contains:
Handset: 1.5.32
Hub: 1.5.2151
It is included in the Cortex Onboard™ app versions:
Cortex Onboard iOS: 1.9.0 (16) upward
Cortex Onboard Android: 1.5.32 (274) upward
Release Notes
  • Alarm control changes
  • Alarm notification changes
  • Directional Alarms on Collision and MOB
  • Collision Profile changes
  • Auto Orientation when using Heading up
  • Cortex Monitor Boat Network fallback
  • Onboarding walk through when handset is turned on for the first time
  • Monitoring connectivity and diagnostics improvements
  • VSWR measurement improvements
  • Cortex Network configuration dialog remembers your password
  • External speaker noise reduction
  • Quiet VHF RX when transmitting on aux VHF
  • Expanded VHF catalogs for Europe
  • UTC time PGN fix
  • True Wind direction and angle fix
  • Handset connectivity and stability improvements
1.4.22 - 03/08/2021
Release Date
March 08, 2021
Release Versions
Cortex v1.4.22 contains:
Handset: 1.4.18
Hub: 1.4.1822
Cortex Onboard iOS: 1.8.6 (1) upward
Cortex Onboard Android: 1.4.18 (262) upward
Release Notes
  • AIS static data fix for GPS antenna location
  • Under the hood software defined radio platform performance improvements
1.4.21 - 02/24//2021
Release Date
February 24, 2021
Release Versions
Cortex v1.4.21 contains:
Handset: 1.4.18
Hub: 1.4.1819
Cortex Onboard iOS: 1.8.5 (0) upward
Cortex Onboard Android: 1.4.18 (256) upward
Release Notes
  • Improves data validity checks on AIS transmissions
  • Fixes an issue with vessel dimension conversion between feet and meters
  • Improvements to DSC call log behavior
  • Fixes an issue with input functionality on GPIO channel 4 and 5
1.4.18 - 01/12/2020
Release Date
January 12, 2020
Release Versions
Cortex v1.4.18 contains:
Handset: 1.4.18
Hub: 1.4.1812
Cortex Onboard iOS: 1.8.4 (0) upward
Cortex Onboard Android: 1.4.18 (254) upward
Release Notes
  •  Fixes a calculation issue when in heading-up mode
1.4.17 -12/15/2020
Release Date
December 15, 2020
Release Versions
Cortex v1.4 contains:
Handset: 1.4.17
Hub: 1.4.1805
Cortex Onboard iOS: 1.8.0 (10) upward
Cortex Onboard Android: 1.4.17 upward
Release Notes
  • Boat Network connectivity
  • Improved Cloud Diagnostics responsiveness
  • Fixed Anchor Watch synchronization issues with Cortex Monitor
  • Handset will auto power on from sleep mode if it was powered off at the switch panel
  • When the ch16 button is pressed immediate visual confirmation of the change provided
  • NMEA 0183 echo setting improvements
  • NMEA 2000 bus connection improvements
Maximum number of Handsets
With the inclusion of Boat Network functionality the maximum number of handsets that can be connected (10) has been split between the Cortex™ Network (5) and the Boat Network (5). Note, using Cortex Onboard app on a mobile device will consume one of these, however, using the NMEA gateway (TCP/IP port 39150) over the Boat Network does not.
Cortex Onboard Wi-Fi Configuration
In order to get the best performance out of the Cortex Onboard connection manager, to get started use the in app configuration options rather than the Apple or Android system's Wi-Fi manager. First connect to the Cortex Network to get the Boat Network details and decide if you want to use your boat network or keep using the Cortex™ Network.
Portable Handsets (model H1P only)
Updating your H1P to v1.4 will require you to reconnect your handset to the Cortex Network. Future updates will not.
1.3.0 - 10/02/2020
Release Date
October 2, 2020
Cortex Onboard iOS version: 1.7.2
Cortex Onboard Android version: 1.2.6
Release Notes:
  • Cortex WiFi connectivity improvements
  • Handset WiFi configuration changes
  • Handset system stability improvements
  • Pressure sensor improvements
  • Minor bug fixes and user interface improvements
1.2.5 - 09/08/2020
Release Date
September 08, 2020
Cortex Onboard iOS version: 1.7.1
Cortex Onboard Android version: 1.2.5
Release Notes:
  • Added input port support for stealth mode and alarm silence buttons
  • Added output port support for an alarm buzzer
  • Included network sensor data streaming to third party apps
  • Improvements to cloud connection stability
1.2.3 - 09/04/2020
Release Date
September 04, 2020
Cortex Onboard iOS version: 1.7.0
Cortex Onboard Android version: 1.2.4
Release Notes:
  • Fix for editing restrictions on AIS static data
  • Fix for MOB test mode control
  • Improvements to the update process
1.2.2 - 09/03/2020
Release Date
September 03, 2020
Cortex Onboard iOS version: 1.6.2
Cortex Onboard Android version: 1.2.3
Release Notes:
  • Added support on the Hub’s GPIO port for smartAIS alarm kit
1.0.0 - First Release
Updating the Cortex
Cortex devices are updated through the Cortex Onboard™ App:
Android
iOS
The Cortex software is downloaded with a Cortex Onboard install or update. This can be done any time there us data coverage or Wi-Fi availability, just like any other App update. Cortex Onboard will then distribute that update to the system next time it connects.
Related
