"Transfer Failed" Error Using the Garmin ActiveCaptain® app
If the onscreen error Transfer Failed appears on either the ActiveCaptain® app or the compatible Garmin device, there are a few troubleshooting steps to consider:
Ensure the smart device stays within the Wi-Fi range of the compatible Garmin chartplotter during the entire transfer.
The ActiveCaptain® app must be actively running and not running in the background of the smart device.
Using a VPN on a smart device can cause the ActiveCaptain app not to work correctly. When troubleshooting syncing issues with ActiveCaptain® app, check to ensure a VPN service isn't being used:
iOS: Go to the iOS Settings > General > VPN
Android: Open the phone's Settings app > Network & internet > VPN
Further troubleshooting steps:
Force close the ActiveCaptain® app
If a connection optimizer app is running on the smart device, temporarily turn off the optimizer app
Power cycle the compatible Garmin chartplotter
Remove and reinsert the micro/SD card in the Garmin chartplotter once it is powered back ON
Reinitialize the transfer
