eTrex® SE
eTrex® Solar
eTrex® Touch 35 | eTrex® Touch 35t
eTrex® Touch
Foretrex® 601 | Foretrex® 701 Ballistic Edition
Foretrex® 801 | Foretrex® 901 Ballistic Edition
GPSMAP® 64s | GPSMAP® 64sc | GPSMAP® 64st | GPSMAP® 64sx | GPSMAP® 64csx
GPSMAP® 65 | GPSMAP® 65s
GPSMAP® 66i | GPSMAP® 66s | GPSMAP® 66sr | GPSMAP® 66st
GPSMAP® 67 | GPSMAP® 67i
GPSMAP® 86i | GPSMAP® 86s | GPSMAP® 86sc | GPSMAP® 86sci
GPSMAP® H1 | GPSMAP® H1i Plus
GPSMAP® 276Cx
Montana® 700 | Montana® 700i | Montana® 710| Montana® 710i | Montana® 750i | Montana® 760i
Oregon® 700 | Oregon® 750 | Oregon® 750t
Rino® 750 | Rino® 750t | Rino® 755t
Smart Notifications on a Garmin Outdoor Handheld
Some outdoor handhelds are able to pair to a smartphone or tablet through Bluetooth®.
This is helpful to be able to tuck your phone or tablet away and see what notifications it receives displayed on your Garmin device instead. For instructions on pairing, refer to your owner's manual.
Managing Smart Notifications
Many of the notifications that appear on the phone or tablet can be displayed on the handheld, such as emails/calls/texts received, calendar events, app alerts, etc.
Notifications can only be deleted from the phone or tablet.
You can manage which notifications show up on your handheld from within the settings of the Garmin Connect™ or Garmin Explore™ apps on Android or your phone/tablet settings on iOS.
Smart Notifications on the handheld can be disabled entirely at any time by going to Setup or Settings, then Phone or Bluetooth, and then toggle off Smart Notifications.
NOTE: Some devices are compatible with both apps. If you use both apps, the notification settings within the Garmin Explore app and Garmin Connect app should be set to match one another.
Garmin Connect App
Open the Garmin Connect app.
Select More (bottom right).
Select Settings.
Select Notifications.
- Select App Notifications.
From here, toggle to enable or disable notifications for All Applications or customize by selecting individual apps.
Garmin Explore App
Open the Garmin Explore app.
Select the profile icon in the top left.
Select App Settings.
Swipe down from the top of the home screen.
Select the Settings Icon.
Select Battery.
Select App Launch.
Select individual or batch select apps, where auto, secondary and run-in-background settings can be disabled/enabled individually
NOTE: You will want to select Disable for Connect (and Explore, if installed) if you are selecting individual apps.
These instructions apply to iOS 16 or higher. Apple® requires these settings to display notifications on connected Bluetooth® devices.
IMPORTANT: For app notifications you do not want to receive on a Garmin device but do want to receive on the phone lock screen, uncheck Notification Center.
Follow the steps below for each app you want to receive notifications from on your Garmin device. Below is an example for Messages.
Select Notifications from the iPhone settings.
Select an application you want to receive notifications from. In this example we will select Messages.
Toggle Allow Notifications on.
Ensure the Notification Center has a checkmark
Ensure Show Previews is set to Always (Default) or When Unlocked.
Following the steps above will result in your phone looking like this:
Android is a trademark of Google LLC.
iPhone, iPad, and Apple are trademarks of Apple Inc., registered in the U.S. and other countries.
