Changing the Screen Brightness on an Automotive Device/Dim or Black Screen
Some devices will not go above 40% brightness when they have low power. This FAQ may also be helpful if your device has a black screen or a very dim screen. To correct this, plug the device into a power source and follow the instructions below.
The device may have a different brightness level set when it is plugged in and unplugged. If the device goes dim when plugged into the vehicle, follow steps 1-4 below before plugging it in. Once it is plugged in, if it goes dim, you can adjust the screen to brighten it using step 4.
The saved brightness level may also need to be adjusted for when the device is on the mount and off of the mount. See the owner's manual for instructions to take the device on and off the mount.
To Change the Screen Brightness:
  1. Touch
  2. Touch Display
  3. Touch "Change..." next to "Brightness"
  4. Adjust the brightness level according to your preference. The screen will dim to the selected brightness while adjusting it.
The saved brightness level may need to be adjusted for Day and Night Mode:
Day Mode provides a white background to improve visibility during daylight hours.
Night Mode darkens the background to prevent the screen from being too bright or distracting when driving in the dark.
To Change the Color Mode:
  1. Touch
  2. Touch Display
  3. Touch Color Mode
  4. Touch the desired color mode
Related
