Using the Xero A1i Locations Widget with the MARQ Series
In order to use the Xero® Locations feature on a compatible Garmin watch you will first need to make sure the latest software update is installed. For updating the software on the Xero bow sight use the instructions here.
Note: View a list of compatible watches and handhelds here.
Follow the steps below to use the Xero Locations widget:
If you need assistance following any of the steps, select Instructions below for steps
1. Add the Xero Locations widget to watch
Instructions
2. Enable broadcast mode on the watch
Instructions
3. Enable Broadcast Mode on the Xero A1i. See the owner's manual for instructions
4. Range or fire a shot with the Xero A1i and send the position to the watch
Instructions
