Entering File Transfer Mode when Connected to a Computer
null
Placing your device in File Transfer Mode is necessary when transferring data to and from your device and the computer.
To Enter File Transfer Mode:
1. Connect the device to the computer with a USB-C cable
2. Select Tap to Connect to Computer
This message will display for a few seconds then slide away
The Tap to Connect to Computer prompt can also be accessed in settings.
Touch the Settings gear icon, then touch Tap To Connect to Computer
3. The device will be in file transfer mode after the countdown or when Continue is selected.
    • Select Cancel to avoid a connection with the computer and remain in operational mode.
An image of a computer wired to a GPS will appear on the device screen while in File Transfer Mode.
The device will continue to operate off external power from your computer. Any charge of the battery from the computer will be minimal.
For additional information on charging your automotive device, see Charging an Automotive Device.
