Features of the Tacx Blue Matic Basic Trainer
Below are details regarding the features of the Tacx Blue Matic trainer that will have influence on your indoor cycling experience.
Flywheel
The Blue Matic is equipped with a 1.25kg (2.75 lbs.) flywheel. The weight of the flywheel in combination with the rotational speed creates a large inertia. This inertia ensures the smoothness of cycling you would expect.
Resistance Level
Blue Matic comes with a lever allowing you to control the amount of resistance the trainer can apply to the rear wheel while you pedal. Blue Matic can simulate up to 700 watts power using the lever.
App Compatibility
Using Garmin's Bluetooth Speed and Cadence sensors will allow you to experience virtual power in many different cycling apps such as the Tacx Training app.
