Using the Range Rings Feature
The range rings feature will allow you to visualize distance to objects on the map. The feature provides a series of circles around your current location. The overall appearance on the map screen will change based on zoom level.
Note: Range rings will display on top-down map views only. The view options include North Up, and Track Up.
  • When set to North Up, the map on a device will display North at the top of the screen at all times.
  • If set to Track Up, the direction in which you're traveling will remain at the top of the screen. Track Up will also include a compass icon on the map view.
To Enable or Disable the Range Rings Feature on the Device:
1. Touch Apps
2. Touch Tools
3. Touch Settings
2. Touch Map Display
3. Enable or disable the Range Rings option.
    • If the toggle icon is green  the option is enabled.
    • If the toggle icon is grey  the option is disabled.
North Up Map Examples:
Street map examples:
Race map examples:
