Importing and Sharing GPX Files on a Tread Device
See the Appropriate Links for More Information on Importing and Sharing GPX Files:
Transferring GPX Files From the Computer to a Memory Card
  1. Format a new memory card card.
  2. With the memory card inserted, connect the Tread device to a computer.
  3. On your computer, locate the Tread device drive with the Memory Card.
  4. Open the Memory Card drive, and create a folder named GPX.
  5. Drag and drop the GPX file(s) into the GPX folder on the memory card,
The files will now be on the memory card.
Importing GPX Files on the Tread Device
  1. Touch Apps
  2. Touch Adventure
  3. Touch Explore
  4. Touch the Three Vertical Dots
  5. Touch Import
  6. Choose GPX files to import and touch OK
    • Options may include Select All, files within Internal Storage, or files within an inserted Memory Card
  7. Select which files to import and touch Next
    • Options may include Select All, Waypoints, Routes, or Tracks
  8. Touch Import
    • Files can be added to a collection if desired
Viewing Routes Transferred from the Computer on the Tread Device
Routes can be created on the computer in programs such as Garmin BaseCamp™ and then transferred to certain models of devices, or to an SD memory card. Once the created routes have been transferred, they can be accessed on the device.
To Access a Transferred Route, Follow the Instructions Below:
  1. Touch Apps
  2. Touch Route Planner
  3. Touch Import
  4. Place a checkmark next to the file you want to import
  5. Touch OK
  6. Place a checkmark next to Routes
  7. Touch Next
  8. Touch Import
    • If using Explore, you can select an existing collection or select a new collection to import the routes into first
The import will begin and display the message "Importing GPX files" indicating that the import is happening. It may take several minutes to import the routes. Once the import is complete, all transferred routes will be displayed under a category called Imported Routes in the Route Planner. Until the route(s) show up in Route Planner, do not turn off the device or connect it to a computer.
Once the route is imported into the device, it may not perfectly match the route you had created in BaseCamp. This is because a route will always use the navigation settings of the device itself.
