Using the Rest Feature for Ultra Run Activities
The Ultra Run activity profile features a rest feature to help you keep track of time spent resting. If laps are being recorded during activities where you did not intend to record a lap, you may need to adjust the function of the Lap Key.
Ultra Run Compatible Watches
NOTE: If you have a compatible Garmin watch and cannot add the Ultra Run activity profile, ensure that your watch software is up to date by syncing with Garmin Express.
  • D2™ Mach 11 | D2™ Mach 1 Pro1
  • Descent™ G2
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
  • Descent™ Mk31 | Descent™ Mk3i1
  • Enduro™
  • Enduro™ 21
  • Enduro™ 31
  • epix™ (Gen 2) - Standard Edition1 | epix™ (Gen 2) - Sapphire Edition1 | epix™ (Gen 2) - Porsche Edition1
  • epix™ Pro (Gen 2) - Standard Edition1 | epix™ Pro (Gen 2) - Sapphire Edition1
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
  • fēnix® 7 - Standard Edition1 | fēnix® 7 - Solar Edition1 | fēnix® 7 - Sapphire Solar Edition1
  • fēnix® 7S - Standard Edition1 | fēnix® 7S - Solar Edition1 | fēnix® 7S - Sapphire Solar Edition1
  • fēnix® 7X - Solar Edition1 | fēnix® 7X - Sapphire Solar Edition1
  • fēnix® 7 Pro - Solar Edition1 | fēnix® 7 Pro - Sapphire Solar Edition1
  • fēnix® 7S Pro - Solar Edition1 | fēnix® 7S Pro - Sapphire Solar Edition1
  • fēnix® 7X Pro - Solar Edition1 | fēnix® 7X Pro - Sapphire Solar Edition1
  • fēnix® 8 - AMOLED Edition1 | fēnix® 8 - Solar Edition1
  • fēnix® 8 Pro - AMOLED | fēnix® 8 Pro - MicroLED1
  • fēnix® E1
  • Forerunner® 1651 | Forerunner® 165 Music1
  • Forerunner® 2551 | Forerunner® 255S1 | Forerunner® 255 Music1 | Forerunner® 255S Music1
  • Forerunner® 2651 | Forerunner® 265S1
  • Forerunner® 570
  • Forerunner® 745
  • Forerunner® 945 | Forerunner® 945 LTE1
  • Forerunner® 9551 | Forerunner® 955 Solar1
  • Forerunner® 9651
  • Forerunner® 970
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
  • MARQ® Adventurer (Gen 2)1 | MARQ® Athlete (Gen 2)1 | MARQ® Aviator (Gen 2)1 | MARQ® Captain (Gen 2)1 | MARQ® Golfer (Gen 2)1
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition1 | MARQ® Athlete (Gen 2) - Carbon Edition1 | MARQ® Athlete (Gen 2) - Performance Edition1 | MARQ® Commander (Gen 2) - Carbon Edition1 | MARQ® Golfer (Gen 2) - Carbon Edition1
  • tactix® 7 - AMOLED Edition1 | tactix® 7 - Standard Edition1 | tactix® 7 - Pro Edition1 | tactix® 7 - Pro Ballistics Edition1
  • tactix® 8 - AMOLED | tactix® 8 - Solar1
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
  • Venu® X1
1These models have the auto rest feature for the Ultra Run activity.
Lap Key Settings
There are four settings for the Lap Key:
  • Lap - Records a lap and displays lap details when the Lap Key is pressed.
  • Rest Only - Starts a rest timer when the Lap Key is pressed. Press the Lap Key again to end the rest period.
  • Lap + Rest - Records a lap, displays lap details, and starts a rest timer when the Lap Key is pressed. Press the Lap Key again to end the rest period and record another lap.
  • Off - The Lap Key will not function during Ultra Run activities.
NOTE: The rest time will not continue to count up if Auto Pause is turned on. See your owner's manual for steps on disabling Auto Pause.
Setting Lap Key Function
  1. Hold UP/Menu.
  2. Select Activities & Apps.
  3. Select Ultra Run.
  4. Select Ultra Run Settings.
  5. Select Lap Key.
  6. Select a Lap Key setting.
Setting Up Auto Rest
Auto Rest is a feature on some Garmin watches for the Ultra Run sport profile. It allows you to record active and rest periods during an ultra run without having to perform button presses or stop the activity. These periods of activity and rest will be reflected in the summary data when viewed directly on the watch, as well as in Garmin Connect™ account.
NOTE: Not available on all models.
  1. Hold UP/MENU.
  2. Scroll to Settings.
  3. Select Activities & Apps.
  4. Select Ultra Run
  5. Select Ultra Run Settings
  6. Select Auto Rest/Pause.
