1. Connect the device to the computer using the provided USB cable
Power on the device if needed.
Insert a card into the device if sending data to a memory card.
2. Open BaseCamp
- Wait for the device to be listed on the left panel.
- Click on the device name to see the memory card listed, if needed.
3. Select the folder or list
containing the data you wish to transfer
Select My Collection to transfer all saved data to the device.
Select items individually in the bottom panel to transfer selected data from the folder or list.
Holding the Ctrl key and clicking on the data will select multiple points or routes.
4. In the menu bar at the top of the screen, select Device, select Send to Device, then select Send ['Name'] to Device... (or Send Selection to Device...)
Example:
5. Select the device or memory card
6. Select OK
The data will now be transferred to the device or memory card.
