Recommended Guidelines for Storing Rechargeable Devices or Batteries in the Off Season
When a handheld is being put into storage for the off-season certain factors, such as battery percentage and temperature can contribute to overall battery health.
Improper storage can shorten battery capacity or disable a battery.
Properly Storing Your Handheld
Follow the information and guidelines below to ensure proper storage of your device so the battery will last for years to come.
  • Ensure the device battery is charged to 30-50%
  • Before placing the device into storage make sure it is fully powered off
    • Display timeout and power save settings can make it look like the device is powered off, when only the display is off
  • If the battery pack or batteries are removeable, remove them from the device before storing
  • Store the device and battery in a cool, dry place at a typical household temperature level (between 68ºF /20ºC and 77ºF/25ºC)
  • Rechargeable batteries self-discharge gradually over time, so monitor and recharge batteries (30-50%) every 3 months while in storage
  • You should recharge the device to 100% before using it again
