Trip Planner Limitations
The Garmin StreetCross™ app and Garmin Motorize™ app allow you to create a multiple-point route. This function allows you to route from point to point without having to enter a new destination after each stop.
  • Each app can store a maximum number of 100 trips.
  • The maximum number of stops/waypoints per trip is 30, excluding the starting and ending points.
  • In reference to the maximum number of stops/waypoints in a single route, the same stop/waypoint should only be used in a trip one time, and not appear twice in the same trip.
If the number of waypoints you want on your route exceeds that app's limitation, it is recommended that you create a separate route for each leg. For example, if you are traveling across the country over several days, it is recommended that you create a separate route for each day.
