Important Notice: Beware of Fake Garmin Ads!
Garmin Philippines has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
MAC Crashes and Reboots When Trying to Connect Over USB
Starting with Mavericks (Mac OS X 10.9), Apple has included FTDI drivers with their system. As such, if all you're using is vmAIS, there's no need for a separate install of the FTDI driver anymore. For Mac OS X 10.3 to 10.8 you will need to download and install a separate FTDI driver, which can be found here.
If there happens to be a separate FTDI driver installed and loaded, accessing the COM port can cause a system crash.
To fix this, run the attached script. To run the script "right click" (click with two fingers) -> Open With -> Other... -> Utilities (down the list) -> Terminal.app. The attached pdf describes the steps being performed by the script and also provides the instructions for manually fixing the issue.
removeFTDIDrivers.sh    1 KB
TB_Mac_USB_Drivers.pdf    100 KB
Related
