Important Notice: Beware of Fake Garmin Ads!
Garmin Philippines has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Alpha 300 or Alpha 300i Not Acquiring GPS Satellites
If your Alpha® 300 or Alpha® 300i dog tracking handheld is not acquiring satellites you should perform the following:
  1. If you are in the field and do not have access to perform a software update skip to step 3, otherwise continue with step 2.
  2. Perform a software update to ensure you are on the latest software available  Software Updates for Alpha 300 and Alpha 300i
  3. If, after performing a software update and with a clear view of the sky, you are still unable to acquire a GPS satellite fix you can enable Multi-GNSS on your handheld by:
    1. Select Setup
    2. Select System
    3. Select Satellite
    4. Select Satellite System
    5. Select Multi-GNSS
  4. If you did not perform the software update in step 2, when you have access return to step 2 and perform a software update.
Related
