1. Select the desired video or photo in the Garmin Drive™ app.
You can delete a video or photo by touching and holding the video or photo and then touching the
Trash icon.
2. Select Allow and Join to connect to Wi-Fi.
3. Trim the video as desired by touching and dragging the arrows on either side of the timeline. Skip this step for photos.
4. Touch Export. Skip this step for photos. The app will prepare the video for upload to your phone and to the Garmin Vault.
- Export can take several minutes, depending on the length of the clip
- When finished, it will say Export Complete
- The video or photo will upload to the Garmin Vault when connected to an active Wi-Fi connection or via your smartphone's cellular connection when this feature is enabled. This takes some time and is not immediate. See How to Enable/Disable the Vault for the Garmin Dash Cam Device.
5. Select Save to Phone.
6. If desired, select OK to add videos to your camera roll.
- The option to Open in Photos will be available.
7. To share your video or photo:
- Go to your Photos on your phone, select the desired video or photo, select your phone's share icon and select the desired sharing options your phone displays.
- Go to the Garmin Vault, select Secure Share, and follow the prompts. See Using the Vault Storage with a Garmin Dash Cam Device for more information.
