Pairing a quatix 3 to a GPSMAP 74xx, 76xx, 84xx and 86xx series
The quatix 3 is compatible with the following series of chartplotters:
  • GPSMAP 74xx
  • GPSMAP 76xx
  • GPSMAP 84xx
  • GPSMAP 86xx
To begin pairing the quatix 3 to the chartplotter the following steps are needed from the chartplotter:
  1. Home
  2. Select Settings
  3. Select Communications
  4. Select Wireless Devices
  5. Select Garmin Wearable
  6. Select Enable Connections: On
  7. Select New Connection
To conclude pairing, on the quatix 3:
  1. Tap the MOB/Start button
  2. Tap the down button until Boat Data is highlighted
  3. Tap the MOB/Start button
  4. They should now be paired successfully
  5. Tap OK on the chartplotter
