Share Routes and Saved Locations via Bluetooth with a BMW Motorrad Navigator V and VI
You can share routes and saved locations with other BMW Motorrad devices using Bluetooth. Routes and saved locations can also be shared via Bluetooth from the BMW Motorrad Navigator VI to the zumo XT. See below for instructions to share this information between BMW devices.
Sharing Routes with Bluetooth
1. Touch Apps
2. Touch Trip Planner
3. Select the route you want to share
4. Touch Menu (three bars in the upper left corner)
5. Touch Share
6. Touch Bluetooth
7. Touch OK
- A list of nearby Bluetooth devices will appear
8. Select the device to add the route to
9. Touch OK
10. Follow the onscreen prompts to complete the transfer
The route will now be loaded to the other device.
Sharing Saved Locations with Bluetooth
1. Touch Where To?
2. Touch Saved
3. Select a saved location to share
4. Touch the Info button
5. Touch Menu (three bars in the upper left corner)
6. Touch Share Place
7. Touch Bluetooth
8. Touch OK
9. Select the device to share the saved location to
10. Touch OK
11. Follow the onscreen prompts to complete the transfer
The saved location will now be loaded to the other device.
