Creating Waypoints and POIs in the Garmin Explore App
Waypoints or Points of Interest (POIs) can be created in the Garmin Explore™ app, then synced to the Garmin Explore™ website or a compatible Garmin® device. You can find steps for this below.
Waypoints can also be created offline, while in the field, and synced to a compatible device. This allows for trip planning without an internet connection.
For steps on navigating waypoints or points of interest in the Garmin Explore app, see - Navigating to a Waypoint or POI in the Garmin Explore App.
Creating a Waypoint/POI at Your Current Location
  1. Open the Garmin Explore app.
  2. Select Map Tab Icon Map.
  3. Tap Plus Symbol.
  4. Select Create Waypoint.
  5. If needed, edit the details of the waypoint by selecting the name or a new icon, or select Details to edit the waypoint coordinates or add notes.
    For more details on waypoint notes, see - Using Waypoint Notes in the Garmin Explore App.
    Waypoint Icons and Details
  6. Select Save.
  7. Select Plus Symbol Add to Collection, if desired.
Creating a Waypoint/POI for a Different Location
  3. Touch on the map where you would like to place the waypoint.
  4. Select Waypoint Icon Mark.
  6. Select Save.
Related
