Scratches, Damage, or Debris on an Approach Launch Monitor
In most cases, scratches will not have any marked influence on performance. However, if the Approach® R10 launch monitor or Approach® R50 launch monitor come in contact with dirt, oil, or other fluids, this can impact functionality. When necessary, clean the surface of the Approach using a cloth dampened with a mild detergent solution, then wipe it dry.
With severe cases of damage, contact Garmin Product Support. Cosmetic damage of any kind is not covered under Garmin's Consumer Limited Warranty.
Related
