Make sure that the SD card is inserted all the way into the video slot on the back of the Garmin DriveCam 76. There are two SD slot on the back side of the device. The SD card slot on the left is for map data, the SD card slot on the right is for video. If no SD card is inserted into the video slot, the device will not record footage. See Installing the Dash Camera Memory Card for more information.
NOTE: The Garmin DriveCam 76 will show a not recording, or paused icon on the main menu if it is not recording video. Press the paused, or the not recording icon, then press the record icon to begin recording.
Example when dash cam is recording:
NOTE: The Garmin DriveCam 76 cannot record video while the Gallery app is open on the device.
The Garmin DriveCam 76 cannot record video when connected to USB only or on a computer. Use the vehicle power adapter provided with your device to use the camera.
Check Dash Cam Settings
If the Garmin DriveCam 76 is not recording when starting the device, Record on Startup may be disabled.
If the Garmin DriveCam 76 is not saving video of events (e.g. collisions or sudden stops), Incident Detection may be disabled.
To Check the Dash Cam Settings on the Garmin DriveCam 76:
1. Touch Settings
2. Touch the down arrow
3. Touch Dash Cam
4. If Record on Startup is unchecked, touch it to add a checkmark
5. Touch Incident Detection
6. Select your preferred incident detection sensitivity, then select Save
NOTE: Selecting Off will disable the dash cam from detecting and saving any incident or impact
The Garmin DriveCam 76 device will now automatically save video when it detects an event.
Check SD Card Compatibility
The Garmin DriveCam 76 device may not be able to record footage onto incompatible SD cards. The Garmin DriveCam 76 requires a Class 10 microSD card and will accept sizes up to 256 GB. See SD Memory Card Sizes for Automotive Devices
You may need to replace the card if the Garmin DriveCam 76 still shows no videos recorded after formatting the card or if the card cannot be formatted. See SD Memory Card Sizes for Automotive Devices for information about recommended card sizes.
