Loading Third-Party Map .IMG files to a Garmin Tread or zūmo XT / zūmo XT2
The Garmin Tread® GPS Navigator and all models in the Tread® series, zūmo® XT, zūmo® XT2 GPS navigators allow for third-party map .IMG files (such as OpenStreetMap - OSM, snowmobile, and other off-road maps) to be loaded and displayed on the device.
NOTES:
- A Windows computer must be used for the steps below. See Automotive Device Compatibility with Garmin Mac Applications on macOS for more information about the use of a Mac computer with the device.
- .IMG files must be located in a "Map" folder on the microSD card and/or the device for your device to display them.
- Garmin cannot provide support or guarantee compatibility for map products or software purchased from other companies. Garmin cannot cover the device under warranty if it becomes unusable as a result of using third-party maps or software.
- For support of third-party map products or software, including setup, usage, and error messages, contact the manufacturer of the map or software program.
To Add the .IMG Files to a MicroSD Card:
- Insert the microSD card into your device
- Connect the device to the computer with the provided USB cable
- Open My Computer (XP), Computer (Vista or 7), File Explorer (Win 8), or This PC (Windows 10)
- Open the Tread® drive or zūmo XT / zūmo XT2 drive from the Devices With Removable Storage or Devices and drives section
- Open the microSD card memory drive
- Right-click in the microSD card drive
- Left-click on New Folder
- Rename the Folder to Map
- Click and drag the desired .IMG files into the Map folder
- Disconnect the device from your computer
The .IMG files will now display under the myMaps settings on your device.
To Add the .IMG Files to the Device:
- Open the device drive from the Devices With Removable Storage or Devices and drives section
- Open Internal Storage or Internal Garmin Storage
- Right-click in the Internal Storage
To Verify the .IMG Files are Displaying on Your Device:
- Touch the Settings Gear
- Touch Map Display or Map & Vehicle
- Touch myMaps
- Enable the maps
- The map is enabled if a checkmark is present.
- Touch the empty box if a checkmark is missing.
NOTE: You may have to disable some Garmin maps for the third-party map to show on the map page of the device. Ensure the Basemap is also enabled.
