Smart Trainer Interference With Treadmill or Virtual Run Activity Distance
If you are seeing no distance or incorrect distance for your Treadmill or Virtual Run activities, and you have previously paired your watch to a smart indoor bike trainer, you may be getting interference from the trainer which is causing the watch to under report your run distance. This can happen on any of the following watches:
D2™ Mach 1 | D2™ Mach 1 Pro
Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
Descent™ Mk3 – 43 mm | Descent™ Mk3i – 43 mm | Descent™ Mk3i – 51 mm
Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
Enduro™
Enduro™ 2
epix™ (Gen 2) - Standard Edition 47 mm| epix™ (Gen 2) - Sapphire Edition 47 mm | epix™ (Gen 2) - Porsche Edition
epix™ Pro (Gen 2) - Standard Edition 42 mm| epix™ Pro (Gen 2) - Sapphire Edition 42 mm
epix™ Pro (Gen 2) - Standard Edition 47 mm| epix™ Pro (Gen 2) - Sapphire Edition 47 mm
epix™ Pro (Gen 2) - Standard Edition 51 mm| epix™ Pro (Gen 2) - Sapphire Edition 51 mm
fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
Forerunner® 265 | Forerunner® 265S
Forerunner® 745
Forerunner® 945 |Forerunner® 945 LTE
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
When recording an activity, the watch will attempt to connect to sensors that have been previously paired. If the watch has previously been connected to a smart indoor bike trainer, the watch may connect to sensors on the trainer and disrupt the data being recorded on the treadmill. To resolve this, we recommend disconnecting the trainer in the Sensors & Accessories menu on the watch before starting a Treadmill or Virtual Run activity. For guidance on how to resolve other distance related issues when using a treadmill, please see the related content.
Disconnecting the Smart Trainer
Hold UP/MENU.
Select Sensors & Accessories.
Select the smart trainer from the list of sensors.
Select Status to set the status of the trainer to Off.
The next time you want to use the smart trainer for an indoor bike activity, you will need to turn the connection status to On again from that same menu.
