Upland Beeper Compatible Devices
The Upland Beeper for the Delta Upland™ or Delta Upland™ XC systems allows the user to locate the dog audibly at a distance and know if the dog is moving (Hunt Mode) or standing still (Point Mode). It is very similar to the Tri-Tronics® G3® Beeper and operates on the same communication system as the Tri-Tronics® G2® Beeper. It is important to keep in mind when setting these systems up for remote beeper use that the beeper is attached to a strap with a corresponding dog device attached to it as well.
Compatible systems1:
- Delta Upland XC (To include a Delta Upland XC Handheld and Delta Upland or Delta Upland XC Collar)
- Delta Upland (To include a Delta Upland Handheld and Delta Upland or Delta Upland XC Collar)
- Pro 5502 (requires a PT 10 collar or a Delta Upland XC collar)
- Sport Upland® G3 EXP (G2/G3 EXP receiver)
- Sport® 65 BPR G2 (G2/G3 EXP receiver)
- Classic 70 G3 or G2 (G2/G3 EXP receiver)
- Trashbreaker G3 or G2 (G2/G3 EXP receiver)
- Field 90 G3 or G2 (G2/G3 EXP receiver)
- Flyway G3 or G2 (G2/G3 EXP receiver)
- Upland G3 or G2 (G2/G3 EXP receiver)
- Pro 100 G3 or G2 (G2/G3 EXP receiver)
- Pro 200 G3 or G2 (G2/G3 EXP receiver)
- Pro 500 G3 or G2 (G2/G3 EXP receiver)
Keeping in mind the limitations and compatibility of the training systems and the beepers will help the user get the most out of the device. For more information on your specific device, please see the owner's manual. To find the owner's manual, visit the Garmin Support Center, identify the specific device you are using, and select manuals on the left of the page. See the Related Content below.
1While all the systems listed above can remotely control the Upland Beeper, Upland Beeper G3 or Upland Beeper G2, it is important to note that the Upland Beeper G3 and G2 both are used on a 1 inch collar strap and the Upland Beeper can only fit a ¾ inch collar strap.
2The Pro 550 Plus is not compatible with the Upland Beeper, Upland Beeper G3 or Upland Beeper G2.
