Customizing Widget Glances on Garmin Outdoor Watches
Widget Glances allow you to see three widgets at a time while scroll through widgets on a compatible Garmin watch. This will allow you to compare information between widgets without having to scroll between them.
Select a widget when in Widget Glances mode to see additional information.
Compatible Watches
  • Descent Mk2 series
  • Enduro series
  • fenix 6 series
  • MARQ series
  • quatix 6
  • tactix Delta series
Widget Glances OnWidget Glances Off
Fenix 6 Widget Glances WeatherFenix 6 Widget Classic Weather
Disabling Widget Glances
Widget Glances can be disabled if you would prefer to see only one detailed widget at a time while scrolling. The device software must be up to date in order to turn off Widget Glances.
  1. Hold Up/Menu
  2. Select Widgets
  3. Toggle OFF Widget Glances
