North America Map Coverage
Current Map Version: 2026.20 (North America) as of June 25, 2025.
Effective with the 2025.20 map release October 9, 2024, devices purchased with a map subscription for a specific North America map region have been upgraded to the full North America map at no extra cost.
During a map update, Garmin Express™ software may prompt you to use a memory card if there isn't enough internal storage for full North American coverage. We recommend using a compatible SD card for the update.
After updating, GPS devices with all of North America installed will display the map as two separate entries:
- CN North America ALL Canada and Mexico
- CN North America ALL US
Other features for your GPS navigator are included with either of the above files. Therefore, both files must be present and checked on your device to ensure full functionality.
For steps to verify the maps installed on the device, go to the Support Center, and enter your Product Name or Serial Number. Once your device is selected, in the Search for a solution... box, type in Verify Maps, then select the corresponding FAQ.
The original maps that came with your device are no longer available to update, as all smaller regions are now included with the full North America map. If you can't update due to space limitations, keep the older version of the map on your device and skip the update.
Click the image to See the Map in Full-Screen Mode.
The following countries and regions are included in the North America coverage:
- United States
- Canada
- Mexico
- Bahamas
- Cayman Islands
- Guadeloupe
- Guyane
- Guam
- Haiti
- Jamaica
- Martinique
- Puerto Rico
- Saint Barthélemy
- Virgin Islands
The coverage listed is not intended to be exhaustive. Refer to the map image for additional information.
You can purchase maps for other countries not included in your map subscription for your compatible device by visiting Garmin's Online Store.
ADDITIONAL NOTES:
- In accordance with the Lifetime Maps and Maps Terms and Conditions, map updates and/or Downloadable Content (DLC) are no longer available to download or purchase and cannot be activated and/or associated with the Garmin devices listed in Map Updates and Downloadable Content No Longer Available to Download or Purchase.
- This is due to these devices not having sufficient memory capacity and other required technical capabilities to utilize current map data.
