Using the Morning Report Feature on My Garmin Watch
The Morning Report feature provides a daily summary of helpful information each morning. This customizable report is pushed to the watch one hour before your set wake-up time allowing you to scroll through information that can vary depending on the model of watch that you have. Available options may include:
  • A Daily Greeting
  • Body Battery™ data
  • Calendar
  • Recovery Advisor
  • Step Goal
  • Step Streak
  • Suggested Workout
  • Upcoming Race Day information
  • Weather
  • Women's Health Tracking (if enabled)
Once dismissed, the morning report cannot be opened again that day. The morning report will dismiss itself two hours after your scheduled wake-up time. If you are not seeing the morning report after confirming you have the feature enabled, see the Related section below to ensure your wake time is set correctly.
Why Am I Seeing Dashes?
When there is data missing, such as the weather data, you will see dashes instead of numerical values.
Customize the Morning Report Feature
Using the watch settings you can enable or disable the morning report and customize which features you see each morning. For some devices, the background colors for your morning report screen may vary depending on:
  • Time of day
  • Current weather outside
  • Viewing morning report before or after sunrise
  • Holidays
To customize the Morning Report select your model below for instructions.
NOTE: Morning Report was rolled out to some watches via a software update so make sure your watch is on the latest software version. For help see Installing the Latest Software On Your Garmin® Device.
Approach® S50 Watch
  1. Press and hold the top button.
  2. Select Settings.
  3. Select Notifications & Alerts
  4. Select Morning Report.
  5. Customize the options below.
    • Show Report: Touch to toggle morning report Off or On.
    • Edit Report: Touch to customize the order and type of data that appears in your morning report.
    • Your Name: Enter the name you would like to show in your morning report.
Approach® S70 Watch
  1. Press ApproachMenuButton.
  2. Select Settings.
D2™ Mach 1 | D2™ Mach 1 Pro Watches
  1. Hold MENU.
  2. Select Appearance.
  3. Select Morning Report.
  4. Customize the options below.
    • Show Report: Press START/STOP to toggle morning report Off or On.
    • Edit Report: Select to customize the order and type of data that appears in your morning report.
Descent™ G2 Watch
  1. Hold MENU.
Descent™ MK3 Watches
These instructions apply to the following watches:
  • Descent™ Mk3 | Descent™ Mk3i watches
  1. Hold MENU.
Enduro™ 2 Watch
  1. Hold MENU.
Enduro™ 3 Watch
  1. Hold UP/MENU (middle left button).
  2. Select Watch Settings.
  3. Select Notifications & Alerts.
    • Show Report: Press START/STOP (upper left button) to toggle morning report Off or On.
    • Clocks: Select to customize Alarms, Timers, and other clock features.
epix™ (Gen 2) - Standard Edition | epix (Gen 2) - Sapphire Edition | epix (Gen 2) - Porsche Edition Watches
  1. Hold MENU.
epix™ Pro (Gen 2) Watches
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition watches
  1. Hold MENU.
fēnix® 7 Watches
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition watches
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition watches
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition watches
  1. Hold MENU.
fēnix® 7 Pro Watches
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition watches
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition watches
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition watches
  1. Hold MENU.
fēnix® 8 - AMOLED | fēnix 8 - Solar Edition Watches
fēnix® E Watch
Forerunner® 165 | Forerunner® 165 Music Watches
  1. Hold the UP key.
    • Show Report: to enable or disable the morning report.
    • Edit Report: to customize the order and type of data that appears in your morning report.
    • Your Name: to customize your display name.
Forerunner® 255 | Forerunner® 255 Music | Forerunner® 255S | Forerunner® 255S Music Watches
  1. Hold the UP key.
Forerunner® 265 Watch
  1. Hold the UP key.
Forerunner® 945 LTE Watch
  1. Hold the UP key.
  4. Select an option:
Forerunner® 955 | Forerunner® 955 Solar Watches
  1. Hold 3 vertically stacked lines to bring up the menu.
Forerunner® 965 Watch
  1. Hold 3 vertically stacked lines to access the menu.
Forerunner® 570 | Forerunner® 970 Watches
  4. Select Report Settings.
  5. Select Morning Report.
  6. Select an option:
    • Customize Daily Messages: to enable or disable customized messages.
Instinct® 2 Watches
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition watches
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition watches
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl™ Edition watches
  • Instinct® 2 Solar | Instinct® 2 Solar - Surf Edition | Instinct® 2 Solar - Tactical Edition watches
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition watches
  1. Hold MENU.
    • Show Report: Press GPS to toggle morning report Off or On.
Instinct® 3 - AMOLED | Instinct® 3 - Solar Watches
  1. Hold MENU.
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition Watches
  1. Hold MENU.
Instinct® E Watch
  1. Hold MENU.
Lily® - Classic Edition | Lily® - Sport Edition Watches
NOTE: If you do not see the Morning Report option on your device, make sure your software is up to date using the Garmin Express™ program.
  1. Wake the watch.
  2. Press Round button on Lily Series to access the menu.
  3. Select Settings.
  5. Toggle Show Report On or Off.
  6. Select Options to customize what you see for your Morning Report.
To customize the display name you will need to go through Garmin Connect™ app > Select your device > Select System > Customize the Display Name > Sync your device to update changes.
Lily® 2 | Lily® 2 Classic Watches
  1. Wake the watch.
  3. Select Settings.
  4. Select Alerts.
  6. Toggle Status On or Off.
  7. Select Options to customize what you see for your Morning Report.
To customize the display name you will need to go through the Garmin Connect™ app > Select your device > Select User Profile > Customize the Display Name > Sync your device to update changes.
Lily® 2 Active Watch
  1. Hold the bottom right button to access the menu.
  2. Select Settings.
  5. Select Status to turn the morning report on or off.
  6. Select Options.
  7. Select an option to include or exclude it from your morning report.
MARQ® (Gen 2) Collection Watches
  • MARQ® Adventurer (Gen 2) watch
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition watch
  • MARQ® Athlete (Gen 2) watch
  • MARQ® Athlete (Gen 2) - Carbon Edition watch
  • MARQ® Athlete (Gen 2) - Performance Edition watch
  • MARQ® Aviator (Gen 2) watch
  • MARQ® Captain (Gen 2) watch
  • MARQ® Commander (Gen 2) - Carbon Edition watch
  • MARQ® Golfer (Gen 2) watch
  • MARQ® Golfer (Gen 2) - Carbon Edition watch
  1. Hold MENU.
quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro Watches
  1. Hold MENU.
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7- Pro Ballistics Edition Watches
  1. Hold MENU.
tactix® 8 - AMOLED Edition | tactix® 8 - Solar Watches
Venu® 3 | Venu® 3S Watches
  1. Hold the bottom button to access the Menu.
  2. Select Settings.
  3. Select Notifications and Alerts.
From this screen, you can turn the report off or on as well as edit the report to customize the information displayed each morning.
Venu® X1 Watch
  1. Press the top right button.
  2. Select Settings.
vívoactive® 5 Watch
  2. Select Settings.
vívoactive® 6 Watch
  1. Press the top button to access the Menu.
  2. Select Settings.
vívosmart® 5 Watch
  1. Press Oval button on vivosmart 5to wake the screen.
  2. Select gear icon to bring up watch settings.
  4. Toggle Status on or off.
  5. Select Options to customize what you see for your morning report.
Related
