Getting Started With The Alpha LTE Collar
null
Pairing Alpha LTE Collar
If you have not previously paired your Alpha® LTE collar to your phone, after the system is fully charged you will need to add the collar to a compatible smartphone and activate it to be tracked.NOTE: To use certain features of this device, it requires an active LTE subscription for the device and must be within an LTE network coverage area. Purchase of an LTE subscription does not guarantee that LTE coverage will be available where the device is used.
Pairing to Your Phone and Activating the Dog Collar Device
null
Dog Tracking
The Alpha® app and a compatible dog tracking handheld allows you to track your dog(s). The map displays your location and your dog's location and tracks. The compass pointer indicates the direction of the dog's current location.Viewing the Alpha LTE Dog Collar Device on your Alpha Dog Tracking Handheld
When the Alpha LTE collar and your compatible Alpha dog tracking handheld are both paired to the Alpha app, a compass pointer appears on the Alpha handheld map page indicating the location of the Alpha LTE collar. The Alpha LTE collar does not appear on the Alpha handheld Dog List page.
Pairing the Alpha LTE Dog Collar to Your Compatible Garmin VHF Dog Tracking Collar
If you are using both the Alpha LTE collar and a compatible Garmin VHF dog tracking collar on your dog you can pair the dog collars so they are tracked together as one asset on the Alpha dog tracking handheld's Dog List page. The Alpha LTE collar is displayed as a tab on the VHF dog collar page.
Pairing to T5, T5 mini, T5X, TT15, TT15 mini, or TT15X Dog Tracking Collar
- Bring your compatible Garmin VHF dog collar within 33 ft. (10 m) of your Alpha LTE collar.
- On the VHF collar press the power button until the status LED rapidly flashes green (indicating pairing mode) and release.
- On the Alpha LTE collar press the power button until the status LED flashes blue (indicating pairing mode) and release.
- The collars will automatically pair within a few seconds.
Pairing to Alpha T20 or Alpha TT25 Dog Tracking Collar
- On both dog collars press the power buttons until the status LEDs flash blue (indicating pairing mode) and release.
NOTE: When successfully paired the status LED on the Alpha LTE collar blinks blue instead of green.
