Displaying Video from a Garmin Marine Chartplotter on a Television or Marine Monitor
Some Garmin chartplotters are able to output video to an external monitor. The following series are the only devices capable of outputting video:
GPSMAP® 3xxx chartplotters
GPSMAP® 4xxx chartplotters
GPSMAP® 5xxx chartplotters
GPSMAP® 6xxx chartplotters
GPSMAP® 70xx chartplotters / GPSMAP® 72xx chartplotters
GPSMAP® 74xx chartplotters / GPSMAP® 76xx chartplotters
GPSMAP® 80xx chartplotters / GPSMAP® 82xx chartplotters
GPSMAP® 86xx chartplotters / GPSMAP® 84xx chartplotters
GPSMAP® 9000 chartplotters
To display the video, the external monitor will need to either have a VGA input using a 15 pin connector, or DVI input in the case of the GPSMAP® 7400 series and GPSMAP® 7600 series and GPSMAP® 8000 series, or HDMI for the GPSMAP® 8600, GPSMAP® 8400, and GPSMAP® 9000 series. To achieve the best visual quality, the monitor will need to be compatible with multi-sync and will need to have the following resolutions available, depending on which device is connected to it:
GPSMAP® 3006C chartplotters / GPSMAP® 3010C chartplotters / GPSMAP® 3206 chartplotters / GPSMAP® 3210 chartplotters
GPSMAP® 4008 chartplotters / GPSMAP® 4208 chartplotters / GPSMAP® 5008 chartplotters / GPSMAP® 5208 chartplotters*
Uses VGA (640 x 480)
GPSMAP® 4010 chartplotters / GPSMAP® 4210 chartplotters*
Uses SVGA (800 x 600)
GPSMAP® 4012 chartplotters / GPSMAP® 4212 chartplotters / GPSMAP® 5012 chartplotters / GPSMAP® 5212 chartplotters / GPSMAP® 5015 chartplotters / GPSMAP® 5215 chartplotters*
XGA (1024 x 768)
GPSMAP® 6008 chartplotters /GPSMAP® 6208 chartplotters**
- VGA (640 x 480)
GPSMAP® 6012 chartplotters / GPSMAP® 6212 chartplotters / GPSMAP® 7012 chartplotters / GPSMAP® 7212 chartplotters / GPSMAP® 7015 chartplotters / GPSMAP® 7215 chartplotters**
XGA (1024 x 768)
GPSMAP® 7410 chartplotters / GPSMAP® 7410xsv chartplotters / GPSMAP® 7610 chartplotters / GPSMAP® 7610xsv chartplotters / GPSMAP® 7412 chartplotters / GPSMAP® 7412xsv chartplotters / GPSMAP® 7612 chartplotters / GPSMAP® 7612xsv chartplotters ***
WXGA (1280 x 800)
GPSMAP® 7616 chartplotters / GPSMAP® 7616xsv chartplotters ***
WXGA (1366 x 768)
GPSMAP® 8008 chartplotters / GPSMAP® 8208 chartplotters ***
SVGA (800 x 600)
GPSMAP® 8012 chartplotters / GPSMAP® 8212 chartplotters / GPSMAP® 8015 chartplotters / or GPSMAP® 8215 chartplotters ***
- XGA (1024 x 768)
GPSMAP® 8600 / GPSMAP® 8400 / GPSMAP® 9000 series
- HDMI
* The GPSMAP® 3xxx chartplotters / GPSMAP® 4xxx chartplotters / GPSMAP® 5xxx chartplotters an use the same video output cable. This Audio/Video cable should come packaged with the chartplotters. If a replacement Audio/Video cable is needed, one can be purchased by clicking here.
** The GPSMAP® 6xxx chartplotters / GPSMAP® 70xx chartplotters / GPSMAP® 72xx chartplotters use a different cable than the other devices. This cable is discontinued and no longer available.
*** The GPSMAP® 74xx chartplotters / GPSMAP® 76xx chartplotters / GPSMAP® 80xx chartplotters / GPSMAP® 82xx chartplotters utilize DVI output and a DVI-I or DVI-D cable can be used to link the chartplotters with a monitor. Garmin sells a DVI-D cable in 6 ft, 15 ft, and 35 ft lengths.
