Editing and Viewing Saved Tracks
You can customize and edit saved tracks directly on the device.
Viewing and Editing a Saved Track:
- Open Apps
- Select Adventure
- Select Tracks
- Select the track you would like to View or Edit
- Selecting
will allow you to view the track, once in the track selecting
will allow for you to see other track data such as speed, elevation, and sharp turns.
- Select the
, the track will now open on the map.
- Add allows you to add more points to the track.
- Delete allows you to remove a track point.
- Move allows you to move a track point.
- Reverse changes the position of the Start and Finish flags.
- Join allows you to select a point of the track and join it with another track from your Track Library.
discards any changes made.
allows you to undo the last change.
- Selecting
- Select Save when you finish your changes
