Importing and Exporting GPX Files on the Overlander
There are a few ways to import GPX files, like waypoints, routes, favorites/saved, and tracks, into the Overlander® GPS navigator. Before following the steps below you must create or sign in to a Garmin Explore™ Account on the Overlander. For instructions, see Logging in to a Garmin Explore Account.
How to Import GPX Files into the Garmin Explore Website and Sync the Overlander via the Wi-Fi Connection
How to Import GPX Files from a microSD Card
- Insert the microSD card loaded with GPX files into the Overlander
- Open the Garmin Explore App
- Touch Library
- Touch EDIT (Top Right Hand Corner of Display)
- Touch Import to Garmin Explore
- Select a box to import the GPX files into a specific Collection or the Unorganized Collection
- Touch IMPORT (Top Right Hand Corner of Display)
The files will then be imported into the selected Collection. Be aware that if you continue to import the files from the same microSD card without removing the previously imported files, you will get duplicate information.
How to Transfer Saved Location and Routes from Another Automotive Device
Windows
1. Plug the device into the computer you want to transfer data from
2. On the keyboard, hold down the Windows key + E
If using Windows 10, click This PC in the new window
3. Double-click the drive labeled with the device name
In Windows 10, the drive will be listed under Devices and Drives:
In Windows 7 and 8, the drive may be listed under Devices with Removable Storage or Portable Devices:
4. Double-click the Garmin device drive
On Windows 7 computers, this may be listed under Devices with Removable Storage.
5. Double-click Internal Storage
Some devices skip this step.
6. Double-click the Garmin folder
7. Double-click the GPX folder
8. Copy the Current.gpx file to the desktop
9. The Current.gpx file can be uploaded to the Garmin Explore Website by following the steps in Importing Waypoints, Routes and Tracks to the Garmin Explore Website
10. Sync the Overlander with the Garmin Explore App by following the steps in Synchronizing Garmin Explore Account Data
Once the syncing is complete, the saved locations will be available in the Garmin Explore App on the Overlander. They will appear in the Library under Waypoints. To navigate to a location stored in the Garmin Explore App see Navigating to a Saved Location. The locations will not be stored in the Saved folder in the Drive menu.
Mac
Note: If transferring saved locations from one of the following devices, it will be easiest to use a Windows computer for this process. If you don't have access to a Windows computer, see Automotive Device Compatibility with Garmin Mac Applications on macOS.
- Arctic Cat G8 Display
Camper 780 & Traffic caravan and motorhome sat nav
Camper 785 & Traffic caravan and motorhome sat nav with camera
Camper 795 caravan and motorhome sat nav
Camper 890 caravan and motorhome sat nav
Camper 895 caravan and motorhome sat nav
Camper 1090 caravan and motorhome sat nav
Camper 1095 caravan and motorhome sat nav
CamperCam 795 motorhome sat nav with built-in dash cam
CamperVan caravan and motorhome sat nav
dēzl™ 780LMT-S GPS navigator
dezl™ LGV500 and dēzl™ OTR500 GPS navigators
dēzl™ LGV610 and dēzl™ OTR610 GPS navigators
dēzl™ LGV620 and dēzl™ OTR620 GPS navigators
dēzl™ LGV700 and dēzl™ OTR700 GPS navigators
dēzl™ LGV710 and dēzl™ OTR710 GPS navigators
dēzl™ LGV720 and dēzl™ OTR720 GPS navigators
dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS navigators with camera
dēzlCam™ LGV725 and dēzlCam™ OTR725 GPS navigators with camera
dēzl™ LGV800 and dēzl™ OTR800 GPS navigators
dēzl™ LGV810 and dēzl™ OTR810 GPS navigators
dēzl™ LGV820 and dēzl™ OTR820 GPS navigators
dēzl™ LGV1000 and dēzl™ OTR1000 GPS navigators
dēzl™ LGV1010 and dēzl™ OTR1010 GPS navigators
dēzl™ LGV1020 and dēzl™ OTR1020 GPS navigators
dēzlCam™ 785 LMT-S GPS navigator with camera
Garmin Catalyst™ Driving Performance Optimizer
Garmin Drive™ 53, Garmin Drive™ 53 & Traffic, and Garmin Drive™ 53 & Live Traffic GPS navigators
Garmin DriveCam™ 76 GPS navigator with camera
Garmin DriveSmart™ 55 & Traffic GPS navigator
Garmin DriveSmart™ 65 & Traffic GPS navigator
Garmin DriveSmart™ 65 with Amazon Alexa GPS navigator
Garmin DriveSmart™ 65 Traveler's Edition GPS navigator
Garmin DriveSmart™ 66 GPS navigator
Garmin DriveSmart™ 71 GPS navigator
Garmin DriveSmart™ 76 GPS navigator
Garmin DriveSmart™ 86 GPS navigator
Kawasaki RIDGE 8" Tread Display
RV 780 & Traffic RV navigator
RV 785 & Traffic RV navigator with camera
RV 795 RV navigator
RV 890 RV navigator
RV 895 RV navigator
RV 1090 RV navigator
RV 1095 RV navigator
RVcam 795 navigator with built-in dash cam
Tread®, Tread® - Base Edition, Tread® 2 series, Tread® - Overland Edition, Tread® XL - Overland Edition, Tread® - SxS Edition, Tread® XL - Baja Chase Edition, and Tread® XL - Baja Race Edition GPS navigators
zūmo® XT and zūmo® XT2 GPS navigators
2. Double-click the GARMIN device drive on the Desktop. This can typically be found mounted in the upper-right corner of the screen.
3. Double-click the Garmin folder (some devices skip this step)
4. Double-click the GPX folder
5. Copy the Current.gpx file to the desktop
6. The Current.gpx file can be uploaded to the Garmin Explore Website by following the steps in Importing Waypoints, Routes and Tracks to the Garmin Explore Website
7. Sync the Overlander with the Garmin Explore App by following the steps in Synchronizing Garmin Explore Account Data
How to Access Saved Locations and Routes on an Overlander if you Already Transferred them from Another Automotive Device in Garmin Express
Note: This can only be done using a Windows computer. If you don't have access to a Windows computer, refer to the steps above to Transfer Saved Locations from Another Automotive Device.
1. Plug the Overlander into the computer
8. Right-click the GarminExpressImport.gpx file
9. Click Cut
10. Right-click on the desktop and click Paste
11. The GarminExpressImport.gpx file can be uploaded to the Garmin Explore Website by following the steps in Importing Waypoints, Routes and Tracks to the Garmin Explore Website
12. Sync the Overlander with the Garmin Explore App by following the steps in Synchronizing Garmin Explore Account Data
How to Export GPX Files from the Overlander into the Garmin Explore App
How to Export GPX Files from the Overlander onto a Memory Card
How to Transfer Saved Locations and Routes from an Overlander to Another Automotive Device
How to Transfer Waypoints, Routes, and Tracks from BaseCamp to an Overlander
Windows
- Connect the device to your computer
- Select an option:
- To send one or more items or a list to the device:
- Click on an item, a list, or multiple items (using CTRL+Click or Shift+Click)
- Click the Device drop-down menu
- Hover over Send To Device
- Click on Send ['Name'] to Device or Send Selection to Device
- To send all saved data to the device:
- Click on the My Collection folder
- Click Send 'My Collection' to Device
- Select the device to which you want to send the selected data
- Click OK
- Unplug the Overlander and turn it on
- Touch the Explore icon
- Touch Library
- Touch Edit
- Touch Import to Explore
- Select temp.gpx
- Touch Select
- Choose a collection or import into unorganized
- Touch Import
It may take a few minutes for the data to appear on the device.
Mac
- Select an option:
- To send one or more individual items to the device:
- Click on a list or the My Collection folder
- Click on an item, or multiple items using Command+Click or Shift+Click
- Click and drag the highlighted items to the device in the upper left-hand corner
- To send a list of all saved data to the device:
- Click the Transfer drop-down menu
- Click Send ['Name'] to Device
- Check the boxes for the data you want to send
- Click Send
- Touch Library
- Touch Edit
- Select temp.gpx
- Touch Select
- Touch Import
