What Is the Garmin Cycling Coach Training Plan?
Garmin Cycling Coach can create a training plan in your Garmin Connect™ account that will send workouts to the device that adapt to your current fitness level. You can also view a week's worth of these workouts on the training calendar in Garmin Connect and see a plan overview and progress within the plan. When setting up the plan you can easily manage your training preferences by selecting the days you want to train or days you prefer to rest.
VO2 max and functional threshold power (FTP) are two key fitness metrics that many cyclists follow as a benchmark for their fitness. Your Garmin device automatically estimates these metrics from rides recorded with heart rate and power data. These metrics provide a foundation for your personalized training plan.
NOTE: Only one Garmin Coach plan can be used at a time.
If you don’t have a current VO2 max estimate on your device, you may need to record a few rides before you can use Garmin Cycling Coach. Refer to this FAQ for more information on VO2 max estimates. To learn more about this feature, see our Garmin Technologies Page or select a topic from the list below:
Cycling Coach Compatible Device List
Workouts will be visible in the Garmin Coach widget on the below watches and cycling computers. If your model is not listed below, it is not compatible with Garmin Cycling Coach. See the following FAQ for cycling training options: Garmin Coach Plans for Cycling.
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ Mk3 | Descent™ Mk3i
  • Edge® 540 | Edge® 540 Solar
  • Edge® 840 | Edge® 840 Solar
  • Edge® 1040 | Edge® 1040 Solar
  • Edge® 1050
  • Edge® MTB
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
  • epix™ Pro (Gen 2) - Sapphire Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED  | fēnix® 8 - Solar
  • fēnix® E
  • Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
  • Forerunner® 265 | Forerunner® 265S
  • Forerunner® 570
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • Forerunner® 970
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Ballistics Edition | tactix® 7 - Pro Edition
  • tactix® 8 - AMOLED | tactix® 8 - Solar
  • Venu® X1
  • vívoactive® 6
Sensor Requirements
To take advantage of Garmin Cycling Coach, you need a compatible Garmin cycling computer or compatible Garmin smartwatch. You also need a heart rate monitor and a power meter paired to your device. If you are using a Garmin smartwatch and cycling computer, you can broadcast your wrist-based heart rate data — captured by the optical sensor — to your cycling computer.
The combination of heart rate and power data allows the Garmin adaptive program to tailor your training precisely. Power shows the effort you are putting into your pedals, while heart rate reflects how hard your body is working to produce that effort. This technology and data ensure your plan adapts to your progress, guiding you toward your cycling goals.
If you have a compatible device paired to your Garmin Connect account, Garmin Cycling Coach can also be used with compatible Tacx® smart trainers using the Tacx Training™ app or Tacx Training™ Desktop app. Refer to Using Garmin Connect Workouts in the Tacx Training App for more information.
For the best results, record all your rides and other cross-training activities with heart rate data. That way, the impact of noncycling activities, such as running or playing tennis, is considered in your cycling training program.
Back to Topics
Can I Reschedule a Workout?
No. If you’ve chosen the Garmin Cycling Coach your plan will be adjusted as optimally as we can based on where you are overall in your plan, your upcoming available days to train, and long workout days.
Back to Topics
What Are Supplemental Strength Workouts?
Some watches provide the option to incorporate strength workouts into your Garmin Cycling Coach plan. You will receive a prompt asking if you want to add strength workouts while you are creating your training plan.
List of Watches Compatible With Supplemental Workouts
  • Enduro™ 3
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 570
  • Forerunner® 965
  • Forerunner® 970
  • Venu® X1
  • vívoactive® 6
If you want to opt in or out of the supplemental strength workouts after the initial setup, choose your platform below for detailed instructions.
Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Training & Planning
  4. Select Garmin Coach Plans.
  5. Select your active plan.
  6. Select in the right corner.
  7. Select Edit Preferences
  8. Select Strength Workouts and make desired changes.
  9. Select Save.
Garmin Connect Web
  1. From a web browser, sign into your Garmin Connect account.
  2. Select Training & Planning from the menu on the left.
  3. Select Garmin Coach Plans.
  4. Select your active plan.
  5. Select Edit next to Preferences.
  6. Select Edit next to Strength Workouts.
  7. Make the desired change.
  8. Select Save.
Back to Topics
What is the Target Type Preference Setting?
The Garmin Cycling Coach plans can adjust the interval target type for prescribed workouts depending on the workout intensity. The following types are available to select:
  • Auto: Switches between Heart Rate and Power depending on the workout intensity. The targets will be set according to the following workout focus:
    • Heart Rate: recovery and base workouts.
    • Power: tempo, threshold, VO2 max, anaerobic, and sprint workouts.
  • Heart Rate: Workouts will use heart rate values for the target intensity.
  • Power: Workouts will use power for the target intensity.
NOTE: The Auto setting is available on all Edge cycling computers, and watches compatible with Supplemental Strength Workouts . Other watches will only have Heart Rate and Pace as target types.
Select your platform below for instructions to adjust the target type preference:
Garmin Connect App:
  6. Select Three black dots stacked vertically in the right corner.
  8. Select Target Type and make desired changes.
  9. Select Save (top right).
Garmin Connect Web:
  6. Select Edit next to Cycling Workout Target.
  8. Select Save.
Back to Topics
Using Training Guidance With a Garmin Connect+ Subscription
With a Garmin Connect + subscription you will access training articles and videos covering topic such as:
  • Plan Phases
  • Specific workout types
  • Training metrics
  • Training tips
Training guidance is generated throughout the plan based on a variety of factors such as: start of the plan, phase of plan, race week, or scheduled workouts.
Back to Topics
Garmin Coach for Cyclists
Back to Topics
Related
