Compatible products can load your Starbucks Card directly to your device using the Starbucks Card app available in the Connect IQ™ store. This allows you to scan the barcode for your Starbucks Card using your Garmin® device.
Setting Up the Starbucks Card App
How Do I Get the Starbucks Card App? For instructions, see - How to Install Connect IQ Content Using the Connect IQ App . The Starbucks Card app is currently available in the United States and Canada. Check the Connect IQ Store page for updates on country availability.
How Do I Add or Change My Starbucks Card Number? To enter your Starbucks Card number via the Connect IQ store:
Open the Connect IQ Store app.
Select My Device (bottom right corner).
Scroll down and select My Device Apps.
Select Starbucks Card .
Select Settings.
Tap Starbucks Card Number .
Enter your Starbucks Card number.
Select Save.
You can also manage your card number directly from your device. For instructions, select your device below.
+ Expand all
Garmin Watches
Approach® Watches, Epix™ (Gen 2) Watches, fēnix® Series, Forerunner® Watches, and Other Multisport WatchesThese steps will work for most devices. For more information refer to your owner's manual .
To add a Starbucks Card number for the first time, follow these steps:
Press the top right button.
Select Starbucks Card.
Follow on screen instructions to enter your Starbucks Card number.
Select confirm, and the barcode will appear on your watch screen.
To change your Starbucks Card number, follow these steps:
Hold the middle left button until the menu appears.
Select Enter Card Number .
Enter your new Starbucks Card number.
Venu® Watches and vívoactive® 4 | vívoactive® 4S | vívoactive® 5 | vívoactive® 6To add a Starbucks Card number for the first time, follow these steps:
Hold the bottom right button until the menu appears.
NOTE: Swipe the screen from right to left instead of holding the bottom button if you have the vívoactive 6.
vívoactive® 3 | vívoactive® 3 MusicTo add a Starbucks Card number for the first time, follow these steps:
Press the center button on the right side.
Hold on the screen until the menu appears.
Garmin Edge Cycling Computers
Edge® 520 Plus | Edge® 530To add a Starbucks Card number for the first time, follow these steps:
Press the down arrow and scroll to Connect IQ.
Scroll through app list and select Starbucks Card.
Select confirm, and the barcode will appear on your device screen.
To change your Starbucks Card number on an Edge 520 Plus, follow these steps:
Hold the top right button until the menu appears.
To change your Starbucks Card number on an Edge 530, follow these steps:
Hold the down arrow until the menu appears.
Edge® 820 | Edge® 830 | Edge® 1030 | Edge® 1030 Plus To add a Starbucks Card number for the first time, follow these steps:
Press the IQ button on the home screen.
Press the menu button on the bottom of the screen.
Select Enter Card Number.
How Do I Uninstall the Starbucks Card App From My Device? To uninstall the Starbucks Card app from your device:
Open the Connect IQ Store.
Select My Device .
Scroll down and select My Device Apps .
Select the (top right)
Select Uninstall .
Can I Manage My Starbucks Account From My Device? To make changes to your Starbucks account, visit https://www.starbucks.com or use the Starbucks mobile app.
