Trigger Button Stopped Working or Cord was Cut on Xero A1 and A1i
If the trigger button or cord for a Xero® A1 or Xero® A1i bow sight is broken or damaged and no longer operational, a replacement can be ordered on Garmin.com.
Using Manual Aiming Methods On Xero A1 or A1i Bow Sights
If an issue with the trigger button is encountered in the field, manual or fixed range pins may be used as long as the sight has been calibrated.
Manual Range Pins
  1. From the main menu select Manual Range Pin Symbol.
  2. Hold the Left or Right arrow button to enter manual range mode.
  3. Use the Left or Right arrow buttons to set the range.
  4. Press OK to lock in the desired range.
Once the range has been set the pin will appear.
Fixed Range Pins
  1. From the Main Menu select Fixed Pin Icon .
  2. Select Fixed Pins.
  3. Select Add Pin.
  4. Use the arrow keys to enter a range and press OK.
  5. Select a pin color and press OK.
  6. Repeat steps 3-5 to add additional pins as desired.
Once fixed range pins have been set up, you can toggle them on or off by pressing the back button while in Hunt  or Practice  mode.
