Updating the Software on a dēzl Headset
The dēzl™ Headset 100, dēzl™ Headset 110, dēzl™ Headset 200, and dēzl™ Headset 210 Premium Trucking Headsets can be updated using the dēzl™ App or the Garmin Drive™ App. The dēzl Headsets can only be paired to the Garmin Drive app if a compatible RV device has already been paired. See Using the dēzl Headset with a Compatible RV Device for more information.
The steps to update are the same for both apps.
NOTE: Do not turn off the headset while an update is installing.
- When an update is available, the dēzl app or Garmin Drive app sends it to the headset automatically.
- The next time you start your headset, it notifies you that it is installing an update.
- Or, you can start the update manually:
- During the update, the Power LED light on the headset will stay illuminated.
- The update takes a couple moments and the headset won't function while updating.
- A progress bar will show during the update.
- After the update is complete, each LED light on the headset will illuminate, then the headset restarts and operates normally.
See dēzl™ App Software Versions or Garmin Drive App Software Versions for a list of software releases and how to check the current version installed.
For the dēzl Headset Software Version:
- From the dēzl™ app or Garmin Drive app, select the gear icon
- Select the dezl Headset
- The software version will be listed
