WIN_XXXXX .CPP or .HPP Error in Garmin Applications
The WIN_XXXXX error can be caused by different factors depending on the Windows operating system.
The Error can Appear as:
- WIN UTILITIES.CPP
- WIN FOUNDFILEIMPL.HPP
- WIN FOUNDFILE.HPP
- WIN FOUNDFILE.CPP
If any of these errors occur, update the application to the latest version.
If this does not resolve the issue, follow the appropriate steps for your operating system:
Windows Vista and Higher:
- Press the Windows key
- Type the name of the application
- In the search list, right-click on the application name
- Click Open file location
- Right-click on the application
- Click Properties
- Click Compatibility
- Check the Run this program as an administrator box
- Click OK
Windows XP:
The WIN CPP / HPP error can occur while creating a backup file in the Windows temp folder. To resolve the error, clear the contents of the temp folder:
- Click Start
- Click Run
- Type %temp%
- Click OK
- Click Edit
- Click Select All
- Right-click on the highlighted files
- Click Delete
- Click Yes to move the items to the Recycle Bin.
Windows will begin deleting the files.
If a Message Appears During This Process Stating That a File Cannot be Deleted:
- Click OK
- Press and hold the Ctrl key
- Click on the file that could not be deleted
- Release the Ctrl key
- Right-click on the remaining highlighted files
- Click Delete
- Repeat the process until the entire folder has been cleared apart from the files that could not be deleted
- Restart the computer
The Garmin application should now open without the error.
