Transferring Tracks from BaseCamp into a Garmin Automotive Device
A track is a recording of your path. A track log contains information about the recorded path including time, location, and elevation information.
You can send tracks (.gpx files) from the BaseCamp™ software into your Automotive device. You can then access them in the Tracks App on the device.
NOTE: When using the Tread® GPS Navigator and all models in the Tread® series, it is recommended to use the Tread® App for managing waypoints, routes, and tracks.
Devices Compatible with Transferring Tracks from BaseCamp
Can-Am Spyder zūmo 590
Harley Davidson Roadtech zūmo 590
BMW Motorrad Navigator V
BMW Motorrad Navigator VI
BMW Motorrad Navigator Street
Tread® - Base Edition GPS Navigator
Tread® - Overland Edition GPS Navigator
Tread® - SxS Edition GPS Navigator
Tread® XL - Baja Chase Edition GPS Navigator
Tread® XL - Baja Race Edition GPS Navigator
Tread® XL - Overland Edition GPS Navigator
zūmo® 390 GPS navigator
zūmo® 390 (Ducati) GPS navigator
zūmo® 395 GPS navigator
zūmo® 396 GPS navigator
zūmo® 590 GPS navigator
zūmo® 595 GPS navigator
zūmo® XT GPS navigator
To Transfer Tracks from BaseCamp for Windows to an Automotive Device
Connect the device to your computer
Select an option:
To send one or more items or a list to the device:
Click on an item, a list, or multiple items (using CTRL+Click or Shift+Click)
Click the Device drop-down menu
Hover over Send To Device
Click on Send ['Name'] to Device or Send Selection to Device
To send all saved data to the device:
Click on the My Collection folder
Click Send 'My Collection' to Device
Select the device to which you want to send the selected data
Click OK
The selected data will now be transferred to your device.
To Transfer Tracks from BaseCamp for Mac to an Automotive Device
Select an option:
To send one or more individual items to the device:
Click on a list or the My Collection folder
Click on an item, or multiple items using Command+Click or Shift+Click
Click and drag the highlighted items to the device in the upper left-hand corner
To send a list of all saved data to the device:
Click the Transfer drop-down menu
Click Send ['Name'] to Device
Check the boxes for the data you want to send
Click Send
To Access the Imported Tracks on the Tread Baja Series Devices
Touch Race Files
Touch the Three Dots in the upper right hand corner
Touch Import
Touch the GPX file that you want to import
Touch OK
Touch Tracks
Touch Next
Touch the Collection you want to add the tracks to
If you do not want to add the track to a collection skip this step.
Touch Import
To Access the Imported Tracks on all Other Automotive Devices
Note: Steps may vary by model
Touch Apps or
Touch Tracks
Touch Adventure first on some devices
Touch the menu (3 horizontal bars), or , then Import
This step can be skipped on some devices as the track will import automatically.
Saved tracks will sync for devices compatible with the Garmin Explore website.
