Instructions for Recording in Standard PAL 25/50 FPS Rates with the VIRB and VIRB Elite
Phase Alternating Line (PAL) is an alternate color encoding system to the National Television System Committee (NTSC). VIRB devices can record using either method1.
To select PAL or NTSC on a VIRB  or VIRB Elite:
  1. Press Mode to get to the Setup page
  2. Select Video
  3. Select Format
  4. Choose the desired format
The VIRB will now record in the selected format.
1If your device does not have the option to switch formats, a software update may be required. For instructions on updating your device see  Updating VIRB Software with Garmin Express.
