Pairing Forerunner 920XT with Garmin Connect Mobile
When paired with your device, the Garmin Connect Mobile app can wirelessly upload and share fitness data with the Garmin Connect website as well as send smart notifications from your smartphone to your wrist.
To pair your Forerunner 920XT choose your phone's platform:
iOS:
  1. Place the iOS device within 10 ft. (3 m) of the Forerunner 920XT
  2. Ensure that Bluetooth is enabled on the iOS device (see iOS device manual for details)
  3. On the iOS device, open the Garmin Connect Mobile application
  4. Touch the More icon located in the lower right corner
  5. Touch Garmin Devices
  6. Touch Add Device
  7. Touch Browse all compatible devices
  8. Touch Forerunner
  9. Touch Forerunner 920XT
  10. Enter each field of required Personal Information if prompted and then touch Next
  11. Press the Menu button on the Forerunner 920XT
  12. Select Settings
  13. Select Bluetooth
  14. Select Pair Mobile Device
  15. Touch Start in the Garmin Connect Mobile application
  16. Touch Yes
  17. Enter the Passkey displayed into the box on the iOS device
  18. Touch Pair
  19. Touch your choice for Activity Tracking.
  20. Touch Done
Android:
  1. Place the Android device within 10 ft. (3 m) of the Forerunner 920XT
  2. Ensure that Bluetooth is enabled on the Android device (see Android device manual for details)
  3. On the Android device, open the Garmin Connect Mobile application
  4. Touch the Menu button (≡) located in the upper-left corner
  6. Touch Add Device
  7. Touch Brows all compatible devices
  8. Touch Forerunner
  12. Select Settings
  15. Touch Search for Device in the Garmin Connect Mobile application
  16. Touch Yes
  17. Enter the Passkey displayed into the box on the Android device
  18. Touch your choice for Activity Tracking, if prompted
  19. Touch OK when the devices are paired
Windows:
  1. Place the Windows phone within 10 ft. (3 m) of the Forerunner 920XT
  2. Ensure that Bluetooth is enabled on the Windows phone (see Windows device manual for details)
  3. On the Windows phone, open the Garmin Connect Mobile application
  6. Touch Add Device
  8. Touch Forerunner
  10. With the Forerunner 920XT in Pairing Mode, touch Add Device
  11. Once discovered, touch the device to pair.
  12. When requested, type or verify the PIN displayed on device and touch Allow
  13. After connection is successful, touch Close and continue
  14. If connection fails, touch Close and troubleshoot pairing
  15. If permissions are requested, touch Yes
  16. Wait for Setup and initial Sync to complete
  17. Once pairing is complete, touch Done
  18. Device is now Paired and Ready
You have now successfully paired the Garmin Connect Mobile application with your Forerunner 920XT, and the device will sync.
