Xero S1 Wrong Language Selected
If the Xero S1 is displaying the wrong language, you can perform a Factory Reset and select the language again.
Note: A Factory Reset will delete all profile and scoring data on the device, and set all menus back to default.
  1. Power the Xero S1 OFF
  2. Press and Hold Power button in
  3. The status light on the lower right of the display will flash green for one second, then flash yellow
  4. Continue to hold Power, but then tap the middle of touchscreen 5 times
  5. Release Power button
  6. Select Language and follow the reset of the setup options as prompted.
