Recommended Pump Size for the Reactor™ 40 Hydraulic Autopilots
Garmin offers several different-size pumps for marine autopilot systems. The boat configuration determines which pump is best suited for the application.
1.0 Liter pump:
Used for single-cylinder applications with cylinder volumes under ten cubic inches
A single-engine under 150 HP
Used on Vessels under 25 feet in LOA
Not used in pressurized air systems
Used in cruising application only, no high-performance situations that include drastic and erratic movements
It is not recommended for fishing or applications that require holding heading while trolling at low speeds or operating in rough waters
It cannot be used in Verado or UFLEX Pro systems
1.2 Liter pump:
For single-cylinder applications with cylinder volumes from 6 to 14 cubic inches
It is a High Pressure / Low Volume pump (HPLV)
Not used in pressurized air systems above 11 psi
Used in low-speed trolling and cruising speed applications
It is intended for many hydraulic systems, including Verado and UFLEX Pro systems
2.0 Liter pump:
For dual-cylinder applications with total cylinder volumes from 10 to 24 cubic inches
It is a Low-Pressure High Volume (LPHV) pump
Only recommend for Low-Pressure hydraulic systems
2.1 Liter pump:
Used for single or multiple cylinder applications with total cylinder volumes of 10 to 24 cubic inches
It is a High Pressure / High Volume pump (HPHV)
Not to be used in pressurized air systems above 11 psi
It is used in low-speed trolling and cruising speed applications
Used in many hydraulic systems, including Verado and UFLEX Pro systems
The 2.1l pump was discontinued and replaced with the SmartPump v2
SmartPump v2:
It is the most responsive autopilot drive system
It is used for single or multiple cylinder applications with total cylinder volumes up to 24 cubic inches
SmartPump v2 is an adaptable pressure and volume pump
Used in pressurized air systems up to 35-40 psi
Recommended for high use, rougher waters, high performance and slow speed applications
Used in many hydraulic systems including Verado and UFLEX Pro systems
SmartPump v1:
The device had the same SPECs as the SmartPump v2 but was discontinued and replaced with the Smart Pump v2 system.
For more information, visit the Autopilot Reference Table.
