Viewing Distant Points of Interest or Addresses on a GPSMAP 62, 64, or 65 Series
When planning an upcoming trip, you may want to ensure certain points of interest or addresses are available on your GPSMAP® outdoor handheld beforehand.
Depending on what you want to view, there are a couple of options listed below for searching in a different location than where you are currently located.
Search Near Function
The Search Near function allows you to view points of interest including cities, tides, or geographical points.
With routable mapping in your GPSMAP handheld, such as City Navigator® or TOPO 24K, you can also view gas stations, restaurants, hotels, entertainment spots, and other similar places.
  1. Press Find
  2. Press Menu
  3. Select Search Near
  4. Press Enter on one of the Search Near options
    • If "A Recent Find" is selected:
      1. Select the recent find to search near
      2. Choose the category of item to search for
    • If "A Waypoint" is selected:
      1. Select the waypoint to search near
    • If "My Current Location" is selected:
      1. Select the category of item to search for near your current location
    • If "A Map Point" is selected:
      1. Move the map so that the cursor or red pin is on the point you wish to use
      2. Press Enter
      3. Select the category of item to search for
The GPSMAP handheld will now provide search results near the different location.
Back to top
Searching for an Address
The ability to search for an address on your GPSMAP handheld requires a routable map, such as City Navigator or TOPO 24K. It is also important that the map covers the area you wish to search in.
The steps vary slightly if you are currently located in the country you want to search within, or if you want to search within another country.
Select an option below for steps.
Address In the Same Country In Which I Am Located
  1. Press Find
  2. Select Addresses
  3. Select Enter State/Province,1 or select the current state/province underneath that
    • 1Select the state/province from the list
  4. Select Enter City/Postal Code, or Search All
    • Use the on-screen keyboard to enter the city or postal code
    • As you type, results may appear. Select Done to choose from the results -or- finish typing, select Done then select city/postal code from the results
  5. Enter the House Number appears on the screen
    • Use the on-screen keyboard to enter the street number. Select Done
  6. Enter the Street Name appears on the screen
    • Use the on-screen keyboard to enter the street name
    • As you type, the closest results appear. Select Done to choose from the results -or- finish typing, select Done then select street name from the results
    • If there are similar or inexact results, a list of addresses may appear. Select desired address
The address will appear on the map. You can use the directional button to pan the map around and the in/out buttons to zoom in or out.
You can also save the address as a waypoint for later use. To do so:
  1. Press Menu
  2. Select Review Point
  3. Press Menu again
  4. Select Save as Waypoint
A confirmation should display that the waypoint was saved. The waypoint can be found under Waypoint Manager, or under Waypoints by pressing Find.
Address In a Different Country In Which I Am Located
  1. Press Find
  2. Select Addresses
  3. Select Enter the Country
    • Use the on-screen keyboard to enter the country name
    • Select country from the results
  5. Enter the Street Name appears on the screen
    • As you type, results may appear. Select Done to choose from the results -or- finish typing, select Done then select street name from the results
  6. Enter the House Number appears on the screen
  1. Press Menu
  3. Press Menu again
Back to top
