nuvi 800 or 805 series not holding a charge
The nuvi 800 and 805 series devices feature a standby mode that allows it to power on instantly when you slide the power key to the on position. While in standby mode the device is still powered on in a reduced powered state. The battery will typically hold a charge while in standby mode for up to 7 days from a full charge. The age of the battery and the environment that it is subjected to can affect the length of time the device can stay in standby mode over time.
Note: If you would like to save the battery charge, remove the battery from the device once it is fully charged. When you are ready to use the device place the battery back into the device and use as normal.
